ENV-VST power ?
Anyone have thoughts on the best way to remotely power the ENV-VST. I purchased one to try at home and we currently only have a 4 conductor there. I will change that when I run the Axlink cable but want to try the stat independently now. Our system is as shown on the two page cut sheet, with the asingle stage furnace and AC. Off memory, the C (common is the missing wire, and they have the 24V jumpered to the AC 24V as shown. Do I just swing that cable to only be on the AC terminal and then land my hot from the wall wart to the 24V and the cold to the common?
Thank you.
