is it possible to pass a structure to a module?
Hello!
Is it possible to pass a structure to a module????
For example, i have the next structure
structure Example:
integer number
char text[50]
And i?ve tried to create a module in different ways, who gets the structure type as a parameter, but none has compiled well and always gives me the same error ("Illegal or invalid syntax in code"), so i don?t know if it is possible to pass an structure as parameter to a module or not.
I?ve tried to do it like the next examples. None worked.
MODULE_NAME='ExampleModule'(struct sExample)
MODULE_NAME='ExampleModule'(struct Example sExample)
MODULE_NAME='ExampleModule'(Example sExample)
Are any correct?
Thanks for your help!!
Salutes.
