IP_Client_Open
when doing IP communication does it need to be in the same class and range of IP. As what I observe. i can' t open the port which is not on the same range of IP... (eg master IP is 10.5.1.101 and IP client is on 10.7.1.101)...
    edgelitoc wrote: »
    What is your subnet set to? If you are using 255.255.255.0, then they are on separate networks and unless you have proper routing, they cannot talk. Also, this is a Private network range, so it is not routable through the internet.
  • edgelitocedgelitoc Junior Member
    Spire_Jeff wrote: »
    yes they are using 255.255.255.0
    Do you have routers configured to allow them to talk with each other? If you set your computer with a 10.5.1.x address, can your computer open a connection to the client?
    Spire_Jeff wrote: »
    I can't Ping it
    Seems like the problem is with the routing configuration of your network. Talk with the IT people and have them help you determine the best solution to the problem.
