IR file can't load to NI ?!
hi~ this is me again!~ the newbie~
current i am involved in a project using two ni-4100 as master and slave, however it is strange.
i am using the same IR file for 4 cams in NI-4000#1 and #2, each have 2 Cams.
the salves' cam can be controlled but the master one cannot. the master's IR just cannot emmit the signal.
i had swapped other's IR port with this 2 and proven that the hardware port is working fine.
i had shorten the cable distance next to the master, it is still not working
voltage meter shows it have less voltage then the working IR PORT(same IR file)
it seems i can't load the file into the IR port, since the port can't emmit anything when other mater can(only for this cam's IR file)ofcause i had checked the program and loading address.
please help!
please help!
i actually using 2 masters with 8 panels and i can control everything, thus, the IP setting, system number setting, url list setting are correct.
let me re-phase my case:
- system number 3 have a url list of system number 4
- they are conencted and i can control both system's devices inculding I/O, Relays, IR, RS232 ports with no problem at all, thus i can control any of 2 masters with any panel to any port.
- at system number 4, port 15,16 are connected to sony camera and using the same IR File, they worked fine
- at system number 3 , port 15,16 are connected to the same sony camera and using the same IR files, however they are not working.
- cable, IR emmitor, polar, program, IR file loading address are all checked, tried to swap the port 13,14 with 15,16. proven that port 15,16 is working in hardware condition.
- when pressing button and tried to emmit, port 15,16 have an expected response,
- but when using IRIS to test, there have nth to come out.
** and then, i am stuck.**
what else can i do to fix it?
