SEND LEVEL TO MET-6N
I am trying to send volume info from an Autopatch 18x18 Precis DSP matrix switcher to the bargraph on a MET-6N keypad. The string from the device displays volume from '( -700 )' to '( 100 )' which is -70dB to +10dB. How do I store this info and then change the range to 0-255 so I can display the volume on the bargraph? I'm running into issues with type conversions.
To solve the problem I ended up doing this...
IF(FIND_STRING(sAUDIO_SWITCH_VOLUME,'M',1)) { nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = -700 ON[nAUDIO_SWITCH_MUTE[nAUDIO_SWITCH_OUTPUT]] nVOL = 0 } ELSE IF(FIND_STRING(sAUDIO_SWITCH_VOLUME,'-',1)) { nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = (ATOL(RIGHT_STRING(sAUDIO_SWITCH_VOLUME,(nSTRING_LENGTH -1))) * (-1)) OFF[nAUDIO_SWITCH_MUTE[nAUDIO_SWITCH_OUTPUT]] GET_BUFFER_CHAR(sAUDIO_SWITCH_VOLUME) nVOL = (((700 - ATOI(sAUDIO_SWITCH_VOLUME)) * 255) / 800) } ELSE { nAUDIO_SWITCH_VOLUME[nAUDIO_SWITCH_OUTPUT] = (ATOL(sAUDIO_SWITCH_VOLUME)) OFF[nAUDIO_SWITCH_MUTE[nAUDIO_SWITCH_OUTPUT]] nVOL = ((((ATOI(sAUDIO_SWITCH_VOLUME))+700) * 255) / 800) } fnAUDIO_SWITCH_VOLUME_UPDATE(nAUDIO_SWITCH_OUTPUT,nVOL)This works fine when I send nVOL to my update level function.
