Samsung TV IR Control
I am working on a proejct with a Samsung LCD TV. The remote will only allow you to scroll through the sources. Currently the set is located in a bedroom with a U-Verse box and a Sony DVD. When I want to change from U-Verse to DVD is requires two "IR Pulses" one for the source change to TV and a second to go to the only other active source DVD. Going from DVD to U-Verse only requires one IR Pulse on source. Does anyone have discrete IR code for the various inputs (i.e. Component, HDMI, Composite) on Samsung TV's? It is a Samsung 4092 LCD TV.
Thanks in advance!
Thanks in advance!
I found one file for eh 4095 series in the MXD format. I ahve teh Parasound Version of URC's program and it wont open the mxd files. Do you know if anyone make a program to conver t to amx.irl orr hex.
