[?] Max number of module
Hi everybody, ( sorry if my English is not good )
I wanted to ask about the maximum number of modules placed in an NI-4100.
In my "main code" i have 26 define module that recall three module write by me;
the first: recall for 15 times, manage the connection of a wireless device
the second: recall for 8 times; manage the rooms
end the last one: recall for 3 times; manage 3 differnt type of room.
If I use all together i have a problem with the connection but, if i remove three ( no difference ), all working well.
It is possible that is a problem about the quantity of memory use ?
Exist a limit about the maximun module that can i use ?
Thanks to all,
Max
Thanks to all,
Max
I would telnet ino your master and see how much memory you have left with out the 3 modules. Do a "show mem" so you can see the break down of memory types and see if you're low in any type. You might be able to change your memory types in your modules by using volatile where you've been using non volatile. There really isn't too much need to declare variables as non volatile since most variables are fine being reset to 0 upon a reboot.
By "a problem with the connection" do you mean you have trouble connecting to the master? It's quite possible that something's stuck in an endless loop in the program which can cause this behaviour.
Which three modules are you removing? Three of the 8 duplicated rooms, or others?
In the test that I have made I delete the three smaller rooms (rooms for staff). I want tell you that those three rooms can be called from the eight larger rooms (rooms for the guests) and that this control is made from a cycle within the "DEFINE_PROGRAM".
Clearly if the wireless device is not online, the request is ignored and I do not think that the problem is inside of this.
Regarding the amount of memory:
whit all the module:
whit out 3 module:
Thanks to all again,
Max
Log into the unit with a terinal program using rs232 and type 'MSG ON ALL'. If you see a flood of error messages you will have found the culprit.
