Used NXT-CV7 not booting?
I picked up a used nxt-cv7 from a client recently, and it's my first touchscreen. I've been using my iphone to control my system at home until now. Question - Can I use a 2.8 power supply to power it? I am using a 2.8, but when the panel boots it gets to the AMX splash screen and then stops. The grey button will not allow me to get into setup, I assume because it can't finish booting. Thoughts? Flash card loose? Should I get a bigger power supply? I do not have the additional base attached, and it's local to the power supply.
I have seen panels lock up at the AMX splash screen when they are not connected to a network. I am not sure why, nor am I certain that what I am describing were the exact scenarios.
Try connecting the Ethernet port to your lan and then booting.
The switching mode power supplies that drive the LCD panels sometimes make a noise like that. If the screen would go to sleep, the noise should stop.
Try holding your finger in the middle of the screen after power-up. There is no other reset I know of.
Let it sit stuck on the AMX splash for a while. Sometimes when stuck, they start up a while later.. like 20 minutes or so.
The hum you hear is not from a "switching mode power supply". That is the inverter which drives the backlight. It is being driven typically at about 1.5kHz on that panel (other panels are different) and the hum is just a harmonic of that frequency usually caused by the inverters vibration.
The finger on the screen during boot will get you into the setup pages when the panel completes its boot. In your case it isn't booting so the touching the display won't help. It is hard to say what the cause but the best bet is that there is something wrong with the CF card. One thing to try that occasionally happens is that someone could have put the CF card in the wrong slot. If you take of the back plastic cover of the panel (I'm assuming table top panel) by removing 4 screws on the bottom (usually hidden under the feet) you will see two CF card slots with the card in one of them. Try taking it out and putting it in the other slot and see what happens. One slot is for a wifi card, the other for the CF card. I can't remember which is which.
If that doesn't work you'll need to call Tech Support and have them send you a new CF card.
What drives the inverter at 1.5KHz? Considering the panel is powered by a external DC supply, it must be a switching mode power circuit.
