how to change system time
Hello,
We have a button that shows the current system time, but we would like to offer the possibility to change this time.
So i?d like to know if there is a way to change the system time through NetLinx code.
Thanks!!
  • felixmoldovanfelixmoldovan Junior Member
    I would go no further than AMX-PI
    SEND_COMMANDs:
       "'CLOCK <mm-dd-yyyy> <hh:mm:ss>'"
          Set the date and time on the Master. The date and time settings are propagated
          over the local bus.
          Syntax:
                SEND_COMMAND <DEV>,"'CLOCK <mm-dd-yy> <hh:mm:ss>'"
          Variable:
                mm-dd-yy = Month, day, and year. Month and day have 2 significant digits.
                                                 Year has 4 significant digits.
                hh-mm-ss = Hour, minute, and seconds. Each using only 2 significant digits.
          Example:
                SEND_COMMAND RS232_1,"'CLOCK 04-12-05 09:45:31'"
                Sets the Masters date to April 12, 2005, and time to 9:45 am.
  • MorgoZMorgoZ Junior Member
    Many thanks!!
    Salutes!
