can c_bus reply
can c_bus reply.i have try everything to make c_bus can reply and i also use the amx's module about the c_bus, but i can't understand all the module .can anyone help ???
thanks for help.
  • filpee
    filpee Junior Member
    c_bus as in the lighting system from clipsal?
  • yanghua_angel
    yanghua_angel Junior Member
    filpee wrote: »
    yes,can it??
  • filpee
    The module comes with a pretty comprehensive user manual with plenty of examples on how to implement both sending and receiving commands.
    heres an example connecting to an Ethernet interface
    DEFINE_DEVICE
    dvCbus	   	= 0:5:0		//CBUS PCI - 192.168.1.10 port 100001
    vdvCbus		= 33003:1:0
    DEFINE_VARIABLE
    volatile char sCbus_Addr[] = '192.168.1.10';
    volatile integer sCbus_Port = 10001;
    DEFINE_MODULE 'CBusModIII' mdlCBUS( dvCBUS, vdvCBUS, sCbus_Addr, sCbus_Port );
    DEFINE_EVENT
    data_event[vdvCbus]
        string:
    	select
    	    active (data.text == "'K:P:[00:3A:02]'"):{
    		//lights are on so do something
        online:
        send_command vdvCBUS, "'STATUS:3A'"
  • yanghua_angel
    i have not use the ip method,but i only use the RS232 method and i can't recieve the reply.
    i use the Channel Feedback,and also no use.
    channel_event[vLight, 18]
    on: on [dvTP, channel.channel]
    off: off [dvTP, channel.channel]
    this also no use
    DEFINE_PROGRAM
    [dvTP, 21] = [vLight,$A9] // group address A9 on local network, app 38
    [dvTP, 22] = [vLight,$AA] // group address AA on local network, app 38
    [dvTP, 23] = [vLight,$AB] // group address AB on local network, app 38
    [dvTP, 24] = [vLight,$AC] // group address AC on local network, app 38
  • wgqkaka
    wgqkaka Junior Member
    filpee wrote: »
    DEFINE_DEVICE
    vdvCbus		= 33003:1:0
    DEFINE_VARIABLE
    DEFINE_EVENT
    data_event[vdvCbus]
        string:
    	select
        online:
    I want to do c_bus?s feedback too,but I have not got feedback message like ?'K:P:[00:3A:02]'?,can you tell me how to get this feedback message?thank you!!!!!
  • Flange_Gasket
    Flange_Gasket Junior Member
    From the examples below it looks like you are using an old version of the Cbus module. AMX have v4.06 but it isn't on the website. For some reason you have to call them and ask for it. It doesn't seem all that much better than the old one, but it's worth a try.
