how can i send code on the thread
hello, i have little question ,how i can send code on the thread ,i saw others can send their code .Can you help me ?
Example: (remove the * symbols when actually posting code)
[*code*]
DEFINE_CONSTANT
TRUE = 1
FALSE = 0
DEFINE_VARIABLE
INTEGER nDogPolisherIsOn = FALSE
[*/code*]
Remove the *'s and it looks like this:
anyone has used the iphone to control your light system ??
i have some problem about the iphone and the master connect setting.
this is diagnostics message.
master's ip is 192.168.1.29.i use the 'AMX_Module_REV02' and i don't know how to set the
my iphone's ip is 192.168.1.8 and in my iphone setting 'CF iviewer' the 'File URL' is 'http://192.168.1.237:8020 ',but when i use the CF iviewer on my iphone will get a Warning message like"Experiencing intermittent connection loss"
my computer's ip is 192.168.1.237 and use the 'CommanFusion guiDesigner' that i set the 'project properties'--'control system'--'Ip Address' is 192.168.1.29 and 'port' is '1319'.
has anyone ad ,thanks a lot.
