Home AMX Forum AMXForums Archive Threads Residential Forum
Finding total value of an array of numbers..
2»
    It might work, but if you remember to do that, you might as well just put a set_length_array command in the define_start section :)
    Spire_Jeff wrote: »
    What's "define_start"?
    Define_start is the section that is run once when a processor first comes online. If you prefer, you could write a function that does the set_length_array and then does the find_string command. This might also be better if you are assigning values to the array using strings and there is a chance that the processor will set the length shorter than the max length.
  • a_riot42a_riot42 AMX Wizard
    Spire_Jeff wrote: »
    I haven't found the need to use set_length_array at all. The array length never changes so I guess I don't understand the need.
    Paul
    I think the problem may stem from my use of a stack_var in this situation. I have not tried it with a volatile variable that is initialized at definition, but that should probably fix the problem.
    a_riot42 wrote: »
    Paul
    I'm not sure I do either. For some reason I was convinced that there was a problem with initializing character arrays that were populated with zeroes, but today I can't find a problem.
    There are two different values for char arrays. There is a length_array and a max_length_array. If you have a variable declared as char sMyString[100], but do not assign anything to it, the length_array = 0 and the max_length_array = 100. If you the do something like sMyString = "'123456789'", the length_array = 9 and max_length_array =100. find_string in the test I ran was using length_array, not max_length_array for it's parsing. As I recall, if you do something like sMyString[50] = '1', the length_array does not change. If I have a minute, I will see if I can write a few tests to clarify all of this. I believe it might also be different for stack_vars vs global variables.
    Ok, I ran some tests and here are the results:
    As you can see, you have to do a set_length_array() for find_string to function properly. The only reason it is functioning properly on the persistent variable is because I have run this a couple times and restarted the processor.
    P.S.
    for display purposes, on the entire array contents, I replaced all of the 0 values with @s. This allows you to see that stack_var arrays are not initialized and could throw false positives if you are not careful.
    On global char arrays:
    Line      1 (16:47:39.609)::  ******Global PERSISTENT char array:
    Line      2 (16:47:39.609)::  $$$   Before changes
    Line      3 (16:47:39.609)::  #  length_array:25     length_string:25
    Line      4 (16:47:39.609)::  #  max_length_array:100    max_length_string:100
    Line      5 (16:47:39.609)::  #  Contents of incoming array:
    Line      6 (16:47:39.609)::  #  String Assigned
    Line      7 (16:47:39.609)::  FIND_STRING is reporting: 20
    Line      8 (16:47:39.609)::  #
    Line      9 (16:47:39.609)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     10 (16:47:39.609)::  #
    Line     11 (16:47:39.609)::  #  Contents of entire array:
    Line     12 (16:47:39.625)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     13 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     14 (16:47:39.625)::  #
    Line     15 (16:47:39.625)::  -------------------------------------------
    Line     16 (16:47:39.625)::  $$$   After insert into indexed position
    Line     17 (16:47:39.625)::  #  length_array:25     length_string:25
    Line     18 (16:47:39.625)::  #  max_length_array:100    max_length_string:100
    Line     19 (16:47:39.625)::  #  Contents of incoming array:
    Line     20 (16:47:39.625)::  #  String Assigned
    Line     21 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     22 (16:47:39.625)::  #
    Line     23 (16:47:39.625)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     24 (16:47:39.625)::  #
    Line     25 (16:47:39.625)::  #  Contents of entire array:
    Line     26 (16:47:39.625)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     27 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     28 (16:47:39.625)::  #
    Line     29 (16:47:39.625)::  -------------------------------------------
    Line     30 (16:47:39.625)::  $$$   After assigning a string
    Line     31 (16:47:39.625)::  #  length_array:15     length_string:15
    Line     32 (16:47:39.640)::  #  max_length_array:100    max_length_string:100
    Line     33 (16:47:39.640)::  #  Contents of incoming array:
    Line     34 (16:47:39.640)::  #  String Assigned
    Line     35 (16:47:39.640)::  FIND_STRING is reporting: 0
    Line     36 (16:47:39.640)::  #
    Line     37 (16:47:39.640)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     38 (16:47:39.640)::  #
    Line     39 (16:47:39.640)::  #  Contents of entire array:
    Line     40 (16:47:39.640)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     41 (16:47:39.640)::  FIND_STRING is reporting: 20
    Line     42 (16:47:39.640)::  #
    Line     43 (16:47:39.640)::  -------------------------------------------
    Line     44 (16:47:39.640)::  $$$   After setting array length
    Line     45 (16:47:39.640)::  #  length_array:25     length_string:25
    Line     46 (16:47:39.656)::  #  max_length_array:100    max_length_string:100
    Line     47 (16:47:39.656)::  #  Contents of incoming array:
    Line     48 (16:47:39.656)::  #  String Assigned
    Line     49 (16:47:39.656)::  FIND_STRING is reporting: 20
    Line     50 (16:47:39.656)::  #
    Line     51 (16:47:39.656)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     52 (16:47:39.656)::  #
    Line     53 (16:47:39.656)::  #  Contents of entire array:
    Line     54 (16:47:39.656)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     55 (16:47:39.656)::  FIND_STRING is reporting: 20
    Line     56 (16:47:39.656)::  #
    Line     57 (16:47:39.656)::  ##########################################
    on Non-Volatile char arrays:
    Line     58 (16:47:39.656)::  ******Global NON_VOLATILE char array:
    Line     59 (16:47:39.656)::  $$$   Before changes
    Line     60 (16:47:39.656)::  #  length_array:0     length_string:0
    Line     61 (16:47:39.656)::  #  max_length_array:100    max_length_string:100
    Line     62 (16:47:39.656)::  #  Contents of incoming array:
    Line     63 (16:47:39.671)::  #
    Line     64 (16:47:39.671)::  FIND_STRING is reporting: 0
    Line     65 (16:47:39.671)::  #
    Line     66 (16:47:39.671)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     67 (16:47:39.671)::  #
    Line     68 (16:47:39.671)::  #  Contents of entire array:
    Line     69 (16:47:39.671)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     70 (16:47:39.671)::  FIND_STRING is reporting: 0
    Line     71 (16:47:39.671)::  #
    Line     72 (16:47:39.671)::  -------------------------------------------
    Line     73 (16:47:39.671)::  $$$   After insert into indexed position
    Line     74 (16:47:39.671)::  #  length_array:0     length_string:0
    Line     75 (16:47:39.671)::  #  max_length_array:100    max_length_string:100
    Line     76 (16:47:39.671)::  #  Contents of incoming array:
    Line     77 (16:47:39.687)::  #
    Line     78 (16:47:39.687)::  FIND_STRING is reporting: 0
    Line     79 (16:47:39.687)::  #
    Line     80 (16:47:39.687)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     81 (16:47:39.687)::  #
    Line     82 (16:47:39.687)::  #  Contents of entire array:
    Line     83 (16:47:39.687)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     84 (16:47:39.687)::  FIND_STRING is reporting: 20
    Line     85 (16:47:39.687)::  #
    Line     86 (16:47:39.687)::  -------------------------------------------
    Line     87 (16:47:39.687)::  $$$   After assigning a string
    Line     88 (16:47:39.687)::  #  length_array:15     length_string:15
    Line     89 (16:47:39.687)::  #  max_length_array:100    max_length_string:100
    Line     90 (16:47:39.687)::  #  Contents of incoming array:
    Line     91 (16:47:39.687)::  #  String Assigned
    Line     92 (16:47:39.703)::  FIND_STRING is reporting: 0
    Line     93 (16:47:39.703)::  #
    Line     94 (16:47:39.703)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     95 (16:47:39.703)::  #
    Line     96 (16:47:39.703)::  #  Contents of entire array:
    Line     97 (16:47:39.703)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     98 (16:47:39.703)::  FIND_STRING is reporting: 20
    Line     99 (16:47:39.703)::  #
    Line    100 (16:47:39.703)::  -------------------------------------------
    Line    101 (16:47:39.703)::  $$$   After setting array length
    Line    102 (16:47:39.703)::  #  length_array:25     length_string:25
    Line    103 (16:47:39.703)::  #  max_length_array:100    max_length_string:100
    Line    104 (16:47:39.703)::  #  Contents of incoming array:
    Line    105 (16:47:39.703)::  #  String Assigned
    Line    106 (16:47:39.718)::  FIND_STRING is reporting: 20
    Line    107 (16:47:39.718)::  #
    Line    108 (16:47:39.718)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    109 (16:47:39.718)::  #
    Line    110 (16:47:39.718)::  #  Contents of entire array:
    Line    111 (16:47:39.718)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    112 (16:47:39.718)::  FIND_STRING is reporting: 20
    Line    113 (16:47:39.718)::  #
    Line    114 (16:47:39.718)::  ##########################################
    on Global Volatile char arrays:
    Line    115 (16:47:39.718)::  ******Global VOLATILE char array:
    Line    116 (16:47:39.718)::  $$$   Before changes
    Line    117 (16:47:39.718)::  #  length_array:0     length_string:0
    Line    118 (16:47:39.718)::  #  max_length_array:100    max_length_string:100
    Line    119 (16:47:39.718)::  #  Contents of incoming array:
    Line    120 (16:47:39.718)::  #
    Line    121 (16:47:39.718)::  FIND_STRING is reporting: 0
    Line    122 (16:47:39.734)::  #
    Line    123 (16:47:39.734)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    124 (16:47:39.734)::  #
    Line    125 (16:47:39.734)::  #  Contents of entire array:
    Line    126 (16:47:39.734)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    127 (16:47:39.734)::  FIND_STRING is reporting: 0
    Line    128 (16:47:39.734)::  #
    Line    129 (16:47:39.734)::  -------------------------------------------
    Line    130 (16:47:39.734)::  $$$   After insert into indexed position
    Line    131 (16:47:39.734)::  #  length_array:0     length_string:0
    Line    132 (16:47:39.734)::  #  max_length_array:100    max_length_string:100
    Line    133 (16:47:39.734)::  #  Contents of incoming array:
    Line    134 (16:47:39.734)::  #
    Line    135 (16:47:39.734)::  FIND_STRING is reporting: 0
    Line    136 (16:47:39.734)::  #
    Line    137 (16:47:39.750)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    138 (16:47:39.750)::  #
    Line    139 (16:47:39.750)::  #  Contents of entire array:
    Line    140 (16:47:39.750)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    141 (16:47:39.750)::  FIND_STRING is reporting: 20
    Line    142 (16:47:39.750)::  #
    Line    143 (16:47:39.750)::  -------------------------------------------
    Line    144 (16:47:39.750)::  $$$   After assigning a string
    Line    145 (16:47:39.750)::  #  length_array:15     length_string:15
    Line    146 (16:47:39.750)::  #  max_length_array:100    max_length_string:100
    Line    147 (16:47:39.750)::  #  Contents of incoming array:
    Line    148 (16:47:39.750)::  #  String Assigned
    Line    149 (16:47:39.750)::  FIND_STRING is reporting: 0
    Line    150 (16:47:39.765)::  #
    Line    151 (16:47:39.765)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    152 (16:47:39.765)::  #
    Line    153 (16:47:39.765)::  #  Contents of entire array:
    Line    154 (16:47:39.765)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    155 (16:47:39.765)::  FIND_STRING is reporting: 20
    Line    156 (16:47:39.765)::  #
    Line    157 (16:47:39.765)::  -------------------------------------------
    Line    158 (16:47:39.765)::  $$$   After setting array length
    Line    159 (16:47:39.765)::  #  length_array:25     length_string:25
    Line    160 (16:47:39.765)::  #  max_length_array:100    max_length_string:100
    Line    161 (16:47:39.765)::  #  Contents of incoming array:
    Line    162 (16:47:39.765)::  #  String Assigned
    Line    163 (16:47:39.765)::  FIND_STRING is reporting: 20
    Line    164 (16:47:39.765)::  #
    Line    165 (16:47:39.765)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    166 (16:47:39.765)::  #
    Line    167 (16:47:39.781)::  #  Contents of entire array:
    Line    168 (16:47:39.781)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    169 (16:47:39.781)::  FIND_STRING is reporting: 20
    Line    170 (16:47:39.781)::  #
    Line    171 (16:47:39.781)::  ##########################################
    on Local_vars:
    Line    172 (16:47:39.781)::  ******LOCAL_VAR char array:
    Line    173 (16:47:39.781)::  $$$   Before changes
    Line    174 (16:47:39.781)::  #  length_array:0     length_string:0
    Line    175 (16:47:39.781)::  #  max_length_array:100    max_length_string:100
    Line    176 (16:47:39.781)::  #  Contents of incoming array:
    Line    177 (16:47:39.781)::  #
    Line    178 (16:47:39.781)::  FIND_STRING is reporting: 0
    Line    179 (16:47:39.781)::  #
    Line    180 (16:47:39.781)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    181 (16:47:39.781)::  #
    Line    182 (16:47:39.796)::  #  Contents of entire array:
    Line    183 (16:47:39.796)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    184 (16:47:39.796)::  FIND_STRING is reporting: 0
    Line    185 (16:47:39.796)::  #
    Line    186 (16:47:39.796)::  -------------------------------------------
    Line    187 (16:47:39.796)::  $$$   After insert into indexed position
    Line    188 (16:47:39.796)::  #  length_array:0     length_string:0
    Line    189 (16:47:39.796)::  #  max_length_array:100    max_length_string:100
    Line    190 (16:47:39.796)::  #  Contents of incoming array:
    Line    191 (16:47:39.796)::  #
    Line    192 (16:47:39.796)::  FIND_STRING is reporting: 0
    Line    193 (16:47:39.796)::  #
    Line    194 (16:47:39.796)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    195 (16:47:39.796)::  #
    Line    196 (16:47:39.796)::  #  Contents of entire array:
    Line    197 (16:47:39.812)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    198 (16:47:39.812)::  FIND_STRING is reporting: 20
    Line    199 (16:47:39.812)::  #
    Line    200 (16:47:39.812)::  -------------------------------------------
    Line    201 (16:47:39.812)::  $$$   After assigning a string
    Line    202 (16:47:39.812)::  #  length_array:15     length_string:15
    Line    203 (16:47:39.812)::  #  max_length_array:100    max_length_string:100
    Line    204 (16:47:39.812)::  #  Contents of incoming array:
    Line    205 (16:47:39.812)::  #  String Assigned
    Line    206 (16:47:39.812)::  FIND_STRING is reporting: 0
    Line    207 (16:47:39.812)::  #
    Line    208 (16:47:39.812)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    209 (16:47:39.812)::  #
    Line    210 (16:47:39.812)::  #  Contents of entire array:
    Line    211 (16:47:39.812)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    212 (16:47:39.828)::  FIND_STRING is reporting: 20
    Line    213 (16:47:39.828)::  #
    Line    214 (16:47:39.828)::  -------------------------------------------
    Line    215 (16:47:39.828)::  $$$   After setting array length
    Line    216 (16:47:39.828)::  #  length_array:25     length_string:25
    Line    217 (16:47:39.828)::  #  max_length_array:100    max_length_string:100
    Line    218 (16:47:39.828)::  #  Contents of incoming array:
    Line    219 (16:47:39.828)::  #  String Assigned
    Line    220 (16:47:39.828)::  FIND_STRING is reporting: 20
    Line    221 (16:47:39.828)::  #
    Line    222 (16:47:39.828)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    223 (16:47:39.828)::  #
    Line    224 (16:47:39.828)::  #  Contents of entire array:
    Line    225 (16:47:39.828)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    226 (16:47:39.843)::  FIND_STRING is reporting: 20
    Line    227 (16:47:39.843)::  #
    Line    228 (16:47:39.843)::  ##########################################
    on Stack_var char arrays:
    Line    229 (16:47:39.843)::  ******STACK_VAR char array:
    Line    230 (16:47:39.843)::  $$$   Before changes
    Line    231 (16:47:39.843)::  #  length_array:0     length_string:0
    Line    232 (16:47:39.843)::  #  max_length_array:100    max_length_string:100
    Line    233 (16:47:39.843)::  #  Contents of incoming array:
    Line    234 (16:47:39.843)::  #
    Line    235 (16:47:39.843)::  FIND_STRING is reporting: 0
    Line    236 (16:47:39.843)::  #
    Line    237 (16:47:39.843)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    238 (16:47:39.843)::  #
    Line    239 (16:47:39.843)::  #  Contents of entire array:
    Line    240 (16:47:39.843)::  #  @$05$022$01$01$0A$07$EF$10@$0A$05$80@Friday, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    241 (16:47:39.843)::  FIND_STRING is reporting: 28
    Line    242 (16:47:39.859)::  #
    Line    243 (16:47:39.859)::  -------------------------------------------
    Line    244 (16:47:39.859)::  $$$   After insert into indexed position
    Line    245 (16:47:39.859)::  #  length_array:0     length_string:0
    Line    246 (16:47:39.859)::  #  max_length_array:100    max_length_string:100
    Line    247 (16:47:39.859)::  #  Contents of incoming array:
    Line    248 (16:47:39.859)::  #
    Line    249 (16:47:39.859)::  FIND_STRING is reporting: 0
    Line    250 (16:47:39.859)::  #
    Line    251 (16:47:39.859)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    252 (16:47:39.859)::  #
    Line    253 (16:47:39.859)::  #  Contents of entire array:
    Line    254 (16:47:39.859)::  #  @$05$022$01$01$0A$07$EF$10@$0A$05$80@Frid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    255 (16:47:39.859)::  FIND_STRING is reporting: 20
    Line    256 (16:47:39.859)::  #
    Line    257 (16:47:39.875)::  -------------------------------------------
    Line    258 (16:47:39.875)::  $$$   After assigning a string
    Line    259 (16:47:39.875)::  #  length_array:15     length_string:15
    Line    260 (16:47:39.875)::  #  max_length_array:100    max_length_string:100
    Line    261 (16:47:39.875)::  #  Contents of incoming array:
    Line    262 (16:47:39.875)::  #  String Assigned
    Line    263 (16:47:39.875)::  FIND_STRING is reporting: 0
    Line    264 (16:47:39.875)::  #
    Line    265 (16:47:39.875)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    266 (16:47:39.875)::  #
    Line    267 (16:47:39.875)::  #  Contents of entire array:
    Line    268 (16:47:39.875)::  #  String AssignedFrid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    269 (16:47:39.875)::  FIND_STRING is reporting: 20
    Line    270 (16:47:39.875)::  #
    Line    271 (16:47:39.875)::  -------------------------------------------
    Line    272 (16:47:39.890)::  $$$   After setting array length
    Line    273 (16:47:39.890)::  #  length_array:25     length_string:25
    Line    274 (16:47:39.890)::  #  max_length_array:100    max_length_string:100
    Line    275 (16:47:39.890)::  #  Contents of incoming array:
    Line    276 (16:47:39.890)::  #  String AssignedFrid1y, Ja
    Line    277 (16:47:39.890)::  FIND_STRING is reporting: 20
    Line    278 (16:47:39.890)::  #
    Line    279 (16:47:39.890)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    280 (16:47:39.890)::  #
    Line    281 (16:47:39.890)::  #  Contents of entire array:
    Line    282 (16:47:39.890)::  #  String AssignedFrid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    283 (16:47:39.890)::  FIND_STRING is reporting: 20
    Line    284 (16:47:39.890)::  #
    Line    285 (16:47:39.890)::  ##########################################
