EXTRON MVC121
got my volume to ramp up and down but the mute button does not toggle. once it is pushed it mutes but will not unmute.
//@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@__PROGRAM_VOL_CONTROL__@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
BUTTON_EVENT[dvTP_202,VolButtons]{
    PUSH:{
	SWITCH(GET_LAST(VolButtons)){
	    CASE 1: SEND_STRING dvMVC,"'+V/v',$0D"
	    CASE 2: SEND_STRING dvMVC,"'-V/v',$0D"
	    CASE 3: SEND_STRING dvMVC,"'3*1!',$0D"
    HOLD[1,REPEAT]:{
  • playskool1playskool1 Junior Member
    SEND_STRING dvMVC,"'3*1!',$0D" //1=ON (unmute)
    SEND_STRING dvMVC,"'3*0!',$0D" //0=OFF (mute)
    SEND_STRING dvMVC,"'3*2!',$0D" //2=mute by contact closure
    i know the protocols go like that.
  • toddttoddt Junior Member
    That is becasue you have to create a toggle function, right now you are just turning on the mute, but don't have anything that would unmute it.
    You could do it this way.
    Define_Variable
    nMute
    PUSH:{
    CASE 3:
    IF(Mute = 0)
    Mute = 1
    Else
    Mute = 0
    HOLD[1,REPEAT]:{
    Example from Extron crosspoint, looks like you need a tracking varible.
    BUTTON_EVENT[VTP,203]
    PUSH:
    IF(AUD_MUTE=0)
    SEND_STRING SWT,SWT_AUDIO_MUTE
    AUD_MUTE=1
    [VTP,203]=AUD_MUTE
    SEND_LEVEL VTP, 1, 0
    ELSE
    SEND_STRING SWT,SWT_AUDIO_UNMUTE
    AUD_MUTE=0
    [VTP,203]=AUD_MUTE
    SEND_LEVEL VTP , 1, ATOI("MM_SWT")
  • enelsonenelson Junior Member
    Yet another approach
    Define_Variable
    mute
    PUSH:
    CASE 3:
    mute=!mute // toggle the mute variable
    SEND_STRING dvMVC,"'3*',mute,'!',$0D" // build the string with the mute value
    HOLD[1,REPEAT]:
    // in your mainline
    [dvtp_202,mute_button number]=(mute=1)
