CSG-544 Analoge input
PascalPascal Junior Member
Can you use analoge telephones with a CSG-544? Because Analoge line 1-4 are not used, and in the user configuration page I can only select input 1-4,not 5-8.
  • RonenRonen Junior Member
    Pascal, you don't see the analog lines 5-8 because you need to "Create" them first:
    Inside the web interface of the SIP gateway go to Telephony -> Service Providers
    Press "Add Service Provider" button and choose "Analog" radio button and select the line you are connected to.
    Press save and then reboot. now it will appar in your lists.
    Ronen
