NO Data in buffer, realy URGENT !!!
I have create buffer, and I can see incoming string, but there is no data in buffer?
What can be a problem ?
I am using some module to controll Philips (BOSCH) DCN system.
URGENT
dvAudioMixer = 5001:1:1 DEFINE_VARIABLE char drugo[500] VOLATILE char trece[500] DEFINE_START create_buffer dvAudioMixer,drugo create_buffer vdvAudioMixer1,trece
URGENT
I see string in notification !!! I sometimes can see it in buffer, but it stop respond after SOME time (less than minute) !!
Also, is the module a duet module? If so, they take control of the physical device and prevent notifications from being seen by netlinx.
HOW ??
Yes, it is duet module !
Is it a Next Generation CCU, or the "old" one?
For the old one there is also an axcent code file on the AMX website
