Biamp Room Combiner
i have a divisible 4 room layout (square layout). im trying to program the biamp DSP to combine and uncombine rooms using these command protocols that were given to me:
SET 1 RMCMBWALL 11 1 0 <LF> //combine 1&2
SET 1 RMCMBWALL 11 4 0 <LF> //combine 2&4
SET 1 RMCMBWALL 11 3 0 <LF> //combine 3&4
SET 1 RMCMBWALL 11 2 0 <LF> //combine 1&3
SET 1 RMCMBWALL 11 1 1 <LF> //separate 1&2
SET 1 RMCMBWALL 11 4 1 <LF> // separate 2&4
SET 1 RMCMBWALL 11 3 1 <LF> // separate 3&4
SET 1 RMCMBWALL 11 2 1 <LF> // separate 1&3
my client wants any way possible the rooms combined except diagonally. example: L shape rooms combined and side-by-side rooms combined.
i am making this simple by just using them in button_events.
now i am only wondering if i typed in the command protocols correctly? the only buttons that worked are buttons 29 and 30.
//@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@__ROOM_COMBINE_MODES__@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ ////////////////////////////////////ALL ROOMS SEPERATED////////////////////////////////////// BUTTON_EVENT[dvTP_1189,29] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 1',$0A" //SEPARATE 1&2 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 1',$0A" //SEPARATE 2&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 1',$0A" //SEPARATE 3&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 1',$0A" //SEPARATE 1&3 } } ////////////////////////////////////ALL ROOMS COMBINED////////////////////////////////////// BUTTON_EVENT[dvTP_1189,30] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 0',$0A" //COMBINE 1&2 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 0',$0A" //COMBINE 2&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 0',$0A" //COMBINE 3&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 0',$0A" //COMBINE 1&3 } } ////////////////////////////////////////1189+1190/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,31] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 0',$0A" //COMBINE 3&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 1',$0A" //SEPARATE 1&2 } } ////////////////////////////////////////1187+1188/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,33] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 0',$0A" //COMBINE 1&2 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 1',$0A" //SEPARATE 3&4 } } ////////////////////////////////////////1187+1189/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,34] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 0',$0A" //COMBINE 1&3 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 1',$0A" //SEPARATE 2&4 } } ////////////////////////////////////////1188+1190/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,32] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 0',$0A" //COMBINE 2&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 1',$0A" //SEPARATE 1&3 } } ///////////////////////////////////1187+1189+1190/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,35] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 0',$0A" //COMBINE 1&3 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 0',$0A" //COMBINE 3&4 } } ///////////////////////////////////1187+1188+1189/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,36] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 0',$0A" //COMBINE 1&2 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 2 0',$0A" //COMBINE 1&3 } } ///////////////////////////////////1187+1188+1190/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,37] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 1 0',$0A" //COMBINE 1&2 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 0',$0A" //COMBINE 2&4 } } ///////////////////////////////////1188+1189+1190/////////////////////////////////////////// BUTTON_EVENT[dvTP_1189,38] { PUSH: { SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 4 0',$0A" //COMBINE 2&4 SEND_STRING dvDSP,"'SET 1 RMCMBWALL 11 3 0',$0A" //COMBINE 3&4 } } DATA_EVENT[dvDSP] { ONLINE: { SEND_COMMAND data.device,"'SET BAUD 38400,N,8,1 485 disable'" } STRING: { WAIT 3 CLEAR_BUFFER cDSP_RESPONSE } }
In this way you greatly reduce the strings to the device. To operate it you just turn on [dvDSP,1] to uncombine rooms 1&2 and turn off [dvDSP,1] to combine 1&2. Now you just have 4 channels to deal with.
or 3 rooms combined. ex:
Just do this....
In this way all of the strings to dvDSP are in the channel event. This makes it easier to modify if you need to make a change in the string.
