iWeather
I am new to using the whole iWeather thing. I am trying to use it with some thermostats. I have it working, the weather is showing up on the thermostats. I am trying to figure out where I put in the ZIP for the thermostat weather. The weather showing up is close to the weather here, but the forecast is way off. any suggestions?
Believe it or not, that feature is disabled on the current version of the module. You have to roll your own. That's what I've done.
Also, the 'Browse the World/Browse the US' funciton is disabled.
It's pretty much just set up to make the thermostats work on whatever zipcode you hard-code in.
Or another way is to get the old version of the module and use it for the non-thermostat i!-Weather stuff. It's not too bad of a memory hog.
