Cool Program - Multiple Software Versions
Not being allowed to have multiple versions of NS on my computer has always been a BIG gripe of mine. I could have not wasted several hours fighting with NS 2.7 if I still had 2.6 installed.
So I started thinking, there's gotta be a way to have both (or mulitple) versions installed. So I did a quick search and I came across a program called Sandboxie. So I started playing around with it - and sure enough, I was able to install multiple versions of the same software which would otherwise not be allowed. I've not tested ALL of the capabilities, but so far - I don't see anything wrong with the previously installed version.
So . . . for those who like to live on the bleeding edge and install new software, this is the way to go.
If anyone installs this and has problems, be sure to post them here and give us a heads-up, as I've only been using this for . . . 20 minutes.
I'm gonna try out installing multiple versions of NS tonight while my wife makes me watch some silly movie called "Twilight" . . . <ugh>
Modifying any workspace, panels, files, etc. is specific to the version you're working in. So if you make any changes in the "sandboxed" program, know that the SAME files are not being modified and instead being copied to a different directory.
Version control could be a pain if you forget about it.
