Time-Manager Problem
Okay - what the heck happened???
The weird thing is - I have three things happening in the system based on the time. Sunrise & Sunset I have things turn off and on respectively. Then at 10:00 PM, I switch on some lights. Well - apparently since forcing the time change - none of this has occurred. Any ideas?
Apparently - the "new" rules are in the version I'm running, which I believe is the most current. (1.0.11)
Edit: I should also mention that I turned on the clock manager in the master. I'm only using the TimeManager module for the sunset / sunrise channel events.
