Polycom Vortex Systems
I have a board room that I am setting up that has an EF2280 (mic Mixer) and EF2201 (telephone interface). There are modules for both of these that I am looking at. The question that I have is should they be seperate devices or should I create 1 device and pass that device to both modules?
Is there an issue with the modules for these devices?
Also, one of the requirements for the first job that I did with them was to be able to use Conference Composer to point to the IP address of the AMX master and tunnel through to the Polycoms so that CC could be run from a central support area instead of sending a tech out to plug in directly.
For the most part, if I am using a lot of the features of a device I'll at least try the AMX module, but if I only need a limited number of functions I'll write my own to keep things small and simple. So I tend to always use the modules for things like VTC units, but for things like projectors or plasmas I'll write my own.
