Weird Quirk with ITOA
Was doing some troubleshooting on a CRC calculation and noticed that when I used ITOA to show some data it gave me some odd results
button_event[10128:1:0,1]
   push:
      stack_var integer crc
      crc = $ffff
      send_string 0,"'Test 1:',itoa(crc << 8)"
      send_string 0,"'Test 2:',itoa(crc + 1)"
Returned:
Test 1:16776960
Test 2:0
Which is odd because I expected Test 1 to be $FF00 not $FFFF00. In digging I found that ITOA's parameter is actually a Long which kinda explains the first result, but then it's not consistent with the second result?
    If you change:
    To this equivalent:
    send_string 0,"'Test 1:',itoa(crc * 256)"
    Then you get the expected result of 65280 ($FF00)
    Weird indeed.
    alexanbo wrote: »
       push:
          crc = $ffff
    Returned:
    Test 1:16776960
    Test 2:0
    It might be an odd behavior of the bitwise shove (<<) as opposed to itoa. What happens if you remove itoa and just print the numbers?
  • alexanboalexanbo Junior Member
    I think it is in itoa, because the calcuation was actually being done correctly, just when I tried to print out intemediary values with itoa that it got funky, sort of a Schr?dinger's Cat sort of thing.
    For example if you added a line before the print statement
    crc = $ffff << 8
    and changed the print statement to:
    send_string 0,"'Test1:',itoa(crc)"
    it would print out the $ff00 decimal equivalent
    alexanbo wrote: »
    crc = $ffff << 8
    Yes, because crc is an integer (16 bits).
    If you said
    STACK_VAR LONG_INTEGER test
    test = $ffff << 8 // or test = $ffff * 256
    then the result is $ffff00, because test is a 32-bit integer.
    It's nothing to do with itoa aside from the fact that its argument is a LONG_INTEGER. The $ffff+1 test may be running into some weird signed/unsigned arithmetic as well.
