Serial command
DenisDenis Junior Member
Hi
I tried a small test with netlink studio, and I tink as it's correct but when I send command trought the TX led on port one dosen't lit why?
PROGRAM_NAME='SNH2009'
(*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
DEFINE_DEVICE
dv_MATRIX	= 5001:1:0
dv_TP		= 10001:1:0
DEFINE_EVENT
DATA_EVENT[dv_MATRIX]
    ONLINE:
	SEND_COMMAND dv_MATRIX, "'SET BAUD 9600,N,8,1 485 DISABLE'"
BUTTON_EVENT [dv_TP,1]
    PUSH:
    SEND_COMMAND dv_MATRIX, "'INPUT- INTERNAL TUNER,1'"
BUTTON_EVENT [dv_TP,2]
    PUSH:
    SEND_COMMAND dv_MATRIX, "'INPUT-INTERNAL TUNER,0'"
If the command are no good, the TX pilot should lit ?
    Denis wrote: »
    Hi
    I tried a small test with netlink studio, and I tink as it's correct but when I send command trought the TX led on port one dosen't lit why? ... If the command are no good, the TX pilot should lit ?
    use send_string instead of send_command...
    // try this
    SEND_STRING dv_MATRIX, "'INPUT- INTERNAL TUNER,1'"
  • Stephen BoltonStephen Bolton Junior Member
    You need to change your button_events to send_string not send_command.
    send_command speaks to the AMX device - therefore your online_event is fine.
  • DenisDenis Junior Member
    Thanks, now the pilot lit..
    But I'm sure as I tried before my post .... sorry, I'm confuse with the doc in module, they spoke about "send_command" and since Matrix is a product of AMX I tried send command too and I dont know why my first (send_string) test has don't work
    SEND_COMMAND is for sending instructions to the device itself; setup parameters, special functions, etc. SEND_STRING tells the device to pass that string through its port.
    Thank for your help
    Only one thing, after many hr of labour, I was confused ( lack experience). The real problem was my "Matser" controler!
    It's run any program who use ip protocol to communicate with interface, (ie: Modero intercom) but when I asked for external command such as serial, relay or IR out the master never send thoses commands. I use a new master and now all work nice!
