Something up with the Date() functions in Duet?
I have a little bit of code that uses the standard Date java stuff like this example:
Then whenever I toss the duet module a command string it will throw back a string like this:
However, when I change the time zone in the clock manager, it changes this time value to reflect local time, but still leaves the GMT tag on it, which seems incorrect, since Date() should always be a UTC absolute value.
So solving the problem for Duet by setting the clock manager to UTC then messes up the local netlinx time for things like touch panels etc.
Anyone have any ideas here?
import java.util.Date;
public class DateTest extends Utility {
public void handleAdvancedEvent(Event obj) {
Date now = new Date();
log(INFO, "Date/Time = " + now);
// Assume rest of standard module here...
(0000274031) com.rsd.datetest.dr3_0_1.DateTest: Date/Time = Tue Feb 10 12:25:18 GMT 2009
But this is not the way Java works. Java would have a specific locale set most likely causing a delta calculation from the internal clock time (which would have to be stored as GMT) each time a date/time value is retrieved. The master currently sets no locale and it is defaulting to GMT (as you've noticed in your printouts)
I will make a note to see if this can possibly be rectified in a future release, but I can't be certain because the two methodologies (AMX=store in local time, Java=store in GMT) are opposite, and changing the master to store in GMT might adversely affect other AMX devices.
