Network usage
in AMX Hardware
Hello All
I am trying to locate information about the network load that a typical 7" panel and NI controller will place on a network for standard communication between the 2 devices during idle mode (no one pushing anything). Does anyone know were to look? I've looked at many places and am unable to find this info.
Remember to use a wired connection and use a hub not a switch to monitor all the network traffic.
In your case, the easiest way to estimate network load between the two nodes is to gather all the packets between them. You need to mirror either touchpanel or netlinx port on a switch and gather the traffic with, for example, wireshark.
(you will find though that there is some network load that does not contribute directly to the traffic between these two, that is generally unavoidable).
Another way is to query snmp agent on netlinx master for the stats. However, you will not be able to get the stats per node, it is aggregated summary (if you have only two AMX nodes, that may useful).
Jeremy
