AXT-CV10
I have an old AXT-CV10. It works fine but the image is slowly fading away. I can't bring the brightness up any more in set up. Is there any repair documentation available or at least a parts list? It may be the backlight, does anyone know of a source for purchasing the backlight or other AMX panel parts?
  • jjames
    dpackard wrote: »
    Call AMX Tech Support and they will provide you with an RMA to send it in and get it repaired (if you're a dealer.) Otherwise, call up AMX, and ask to find a dealer that you can take it to and have them send it in for you.
  • dpackard
    dpackard Junior Member
    That was the obvious answer and conclusion I had already came to before I wrote the request for information. I simply wanted to know if there were OTHER alternatives.
    DP
  • jjames
    dpackard wrote: »
    DP
    I just highly doubt there's a place where you can buy the parts from - unless of course you tear it apart and get a list of what's in there. Just like most other pieces with a name on it - they almost always use someone else's stuff. I really doubt it's all manufactured by AMX.
