Could someone post an example for the usage of ASTRO_CLOCK? Should I put this in define_program? I need sunrise & sunset times everyday to manage some lighting controls.
You get a button event when Sunrise or Sunset time has been reached. (Of course you got to make sure your latitude/longitude settings are correct)...
(* BUTTON_EVENT: Sunrise Channel *)
(* PURPOSE: Channel is pushed (and turned on) when *)
(* the Sunrise occurs *)
BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel]
PUSH:
SEND_STRING 0,"'Sunrise occured at ',TIME"
(* BUTTON_EVENT: Sunset Channel *)
(* the Sunset occurs *)
BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel]
PUSH:
SEND_STRING 0,"'Sunset occured at ',TIME"
// full code
(* AMX Corporation *)
(* Copyright (c) 2000 - 2005 AMX Corporation. All rights reserved. *)
(* please refer to EULA.TXT for software license agreement *)
(* i!-TimeManager (1.0.11) *)
PROGRAM_NAME='i!-TimeManagerTest'
(*{{PS_SOURCE_INFO(PROGRAM STATS) *)
(* ORPHAN_FILE_PLATFORM: 1 *)
(*}}PS_SOURCE_INFO *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
DEFINE_DEVICE
vdvTmEvents = 33001:1:0
dvTmTimeSync = 0:3:0
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
(* Timeserver protocols *)
nProtoNone = 0
nProtoDaytime = 1
nProtoTime = 2
nProtoSNTP = 3
nProtoSNTPBCast = 4
(* Channels *)
nTmSunriseChannel = 1
nTmSunsetChannel = 2
nTmDstChannel = 3
nTmTimeChangeChannel = 4
(* Levels *)
nTmGmtEffLevel = 1
nTmGmtLevel = 2
nTmLongLevel = 3
nTmLatLevel = 4
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
DEFINE_VARIABLE
(* Timezone *)
CHAR dTmTzName[100]
CHAR dTmTzDesc[10]
DOUBLE dTmTzGmtOffset
CHAR strTmTzDstRules[1000]
(* Location *)
CHAR strTmLocName[100]
DOUBLE dTmLocLong
DOUBLE dTmLocLat
(* Timeserver *)
INTEGER nTmTsProtocol
INTEGER nTmTsCheckTime
CHAR strTmTsServer[100]
(* SUBROUTINE DEFINITIONS GO BELOW *)
(* STARTUP CODE GOES BELOW *)
DEFINE_START
(* Step 1 - Configure the timezone: *)
// Configure Timezone
// Parameter 1: Timezone Name. ex: "Eastern"
// Parameter 2: Timezone description. ex: "E%sT"
// Parameter 3: Timezone GMT offset in hours. ex: -5.0
dTmTzName = 'Central'
dTmTzDesc = 'C%sT'
dTmTzGmtOffset = -6.0
// Configure Timezone Rules *)
// Parameter 1: Daylight savings string. ex: "None", "US" or custom.
// Custom string: "Month" "DayDescription" "Time" "Offset From Std" "Descrption"
// "Month": Month name ex: "Apr"
// "Time" Time to activate (hh:mm:ss, 24 hour). ex: "02:00:00"
// "Offset From Std" Time to offset from GMT (hh:mm:ss, 24 hour). ex: "01:00:00"
// "Description" String to replace "%s" with in Timezone description. ex: 'D'
// "DayDescription" Day Description. Fixed Date, Last Day Of Week or
// First Day of Week Before/After Date
// Fixed ex: "15"
// Last Day of Week ex: "LastSunday"
// First Day of Week Beforer DATE-ex: "Sun<=24"
// First Day of Week After DATE-ex: "Sun>=1"
strTmTzDstRules = 'US'
(* Step 2 - Configure Physical Location: *)
// Configure Physical Location
// Parameter 1: Location Name. ex: 'Seattle'
// Parameter 2: Location Longitude. ex: -122.33 (>0 == East, < 0 == West)
// Parameter 3: Location Latitude. ex: 47.6 (>0 == North, < 0 == South)
strTmLocName = 'Dallas'
dTmLocLong = -96.76
dTmLocLat = 32.79
// You can find longitude/latitude values and descriptions at:
// http://geography.about.com/cs/latitudelongitude/
// http://www.census.gov/cgi-bin/gazetteer
// http://www.njdxa.org/landl-lookup-dx.shtml
(* Step 3 - Configure Time servers: *)
// Configure Time servers
// Parameter 1: Protocol, 0=Disbaled, 1=DayTime(13/udp, 13/tcp), 2=Time(37/udp, 37/tcp), 3=SNTP(123/udp), 4=SNTP Broadcast (137/udp). ex: 2
// Parameter 3: Default Server. ex: 'mytimeserver.mydomain.com'. Leave blank to read from time sevrer file (time/nist_svr.lst)
// Parameter 2: Check Time interval in seconds. Use 0 for default (2 hours). ex: 3600
// Parameter 4: Prefered Index of Timeservers in list. ex: 2
// Notes: If parameters 3 is supplied, parameter 4 is ignored
// If paramater 3 is an empty string and parameter 4 is 0, a default will be picked from the list is possible
//nProtoNone = 0
//nProtoDaytime = 1
//nProtoTime = 2
//nProtoSNTP = 3
//nProtoSNTPBCast = 4
nTmTsProtocol = nProtoSNTP
nTmTsCheckTime = 0
strTmTsServer = ''
(* Alternate Manual Timezone configurations: *)
// These are shown for example purposes and represent information that is not guaranteed to be correct!
// Here is an exmaple configuration for Santiago, Chile which is -4 hours behind GMT and observes Daylight savings starting
// on the Saturday on or after October 9th at midnight (jump ahead 1 hour) and the Saturday on or after the 9th of March at midnight (jump back 1 hour)
// and describes the time as "hh:mm:ss CST" or "hh:mm:ss CDT" depending on Daylight savings and is located at "33s27, 70w40":
//dTmTzName = 'Santiago'
//dTmTzDesc = 'C%sT'
//dTmTzGmtOffset = -4.0
//strTmTzDstRules = "'Oct Sat>=9 00:00:00 01:00:00 D',$FF,'Mar Sat>=9 00:00:00 00:00:00 S'"
// AND
//strTmLocName = 'Santiago'
//dTmLocLong = -70.67
//dTmLocLat = -33.45
// Here is an exmaple configuration for Sydney, Australia which is +10 hours ahead of GMT and observes Daylight savings starting
// on the Last Sunday in October 2:00 AM (jump ahead 1 hour) and the Last Sunday in March at 3:00 AM (jump back 1 hour)
// and describes the time as "hh:mm:ss EST" regardless of Daylight savings and is located at "33s52, 151e13":
//dTmTzName = 'Sydney'
//dTmTzDesc = 'EST'
//dTmTzGmtOffset = 10.0
//strTmTzDstRules = "'Oct LastSun 02:00:00 01:00:00 X',$FF,'Mar LastSun 03:00:00 00:00:00 X'"
// AND
//strTmLocName = 'Sydney'
//dTmLocLong = 151.22
//dTmLocLat = -33.86
// Here is the example configuration for London, England which uses GMT and observes Daylight savings starting
// on the last Sunday in March at 1:00 AM (jump ahead 1 hour) and the Last Sunday in October at 2:00 AM (jump back 1 hour)
// and describes the time as "hh:mm:ss BST" or "hh:mm:ss GMT" depending on Daylight savings and is located at "51n30, 0w10":
//dTmTzName = 'London'
//dTmTzDesc = '%s'
//dTmTzGmtOffset = 0.0
//strTmTzDstRules = "'Mar LastSun 01:00:00 01:00:00 BST',$FF,'Oct LastSun 02:00:00 00:00:00 GMT'"
// AND
//strTmLocName = 'London'
//dTmLocLong = -0.16
//dTmLocLat = 51.50
(* THE MODULE CODE GOES BELOW *)
DEFINE_MODULE 'i!-TimeManagerMod' mdlTM(vdvTmEvents,
dvTmTimeSync,
(* Timezone *)
dTmTzName,
dTmTzDesc,
dTmTzGmtOffset,
strTmTzDstRules,
(* Location *)
strTmLocName,
dTmLocLong,
dTmLocLat,
(* Timeserver *)
nTmTsProtocol,
nTmTsCheckTime,
strTmTsServer)
(* THE EVENTS GOES BELOW *)
DEFINE_EVENT
PUSH:
PUSH:
(* BUTTON_EVENT: DST Activity Channel *)
(* the DST rules affect a time change with *)
(* a non-zero time offset (DST Active) *)
(* Channel is release (and turned off) when *)
(* a zero time offset (DST Inactive) *)
BUTTON_EVENT[vdvTmEvents,nTmDstChannel]
PUSH:
SEND_STRING 0,"'DST is now active: ',TIME"
RELEASE:
SEND_STRING 0,"'DST is now inactive: ',TIME"
(* BUTTON_EVENT: Time Change Channel *)
(* PURPOSE: Channel is pushed (and pulsed) when *)
(* the Time is changed by a communication *)
(* with a time server. *)
BUTTON_EVENT[vdvTmEvents,nTmTimeChangeChannel]
PUSH:
SEND_STRING 0,"'Time adjusted by time server. New Time is ',TIME"
(* LEVEL_EVENT: Effective GMT Offset *)
(* PURPOSE: Level is sent whenever the effective GMT *)
(* offset is changed. The effective offset *)
(* is the real GMT offset with DLS correction*)
LEVEL_EVENT[vdvTmEvents,nTmGmtEffLevel]
SEND_STRING 0,"'Effective GMT Offset=',FTOA(LEVEL.VALUE)"
(* LEVEL_EVENT: GMT Offset *)
(* PURPOSE: Level is sent whenever the GMT *)
(* offset is changed. *)
LEVEL_EVENT[vdvTmEvents,nTmGmtLevel]
SEND_STRING 0,"'GMT Offset=',FTOA(LEVEL.VALUE)"
(* LEVEL_EVENT: Longitude *)
(* PURPOSE: Level is sent whenever the longitude is *)
(* changed. *)
LEVEL_EVENT[vdvTmEvents,nTmLongLevel]
SEND_STRING 0,"'Longitude=',FTOA(LEVEL.VALUE)"
(* LEVEL_EVENT: Latitude *)
(* PURPOSE: Level is sent whenever the Latitude is *)
(* changed. *)
LEVEL_EVENT[vdvTmEvents,nTmLatLevel]
SEND_STRING 0,"'Latitude=',FTOA(LEVEL.VALUE)"
(* DATA_EVENT: Strings for Sunrise/Sunset *)
(* PURPOSE: parse strings for sunrise and sunset *)
DATA_EVENT[vdvTmEvents]
STRING:
STACK_VAR
CHAR strUpper[30]
CHAR strTemp[30]
CHAR strTrash[30]
strUpper = UPPER_STRING(DATA.TEXT)
strTemp = DATA.TEXT
strTrash = REMOVE_STRING(strTemp,'-',1)
SELECT
(* SUNRISE *)
ACTIVE (FIND_STRING(strUpper,'SUNRISE-',1)):
SEND_STRING 0,"'Sunrise Time=',strTemp"
(* SUNSET *)
ACTIVE (FIND_STRING(strUpper,'SUNSET-',1)):
SEND_STRING 0,"'Sunset Time=',strTemp"
(* TIME ZONE NAME *)
ACTIVE (FIND_STRING(strUpper,'TIMEZONE-',1)):
SEND_STRING 0,"'Timezone=',strTemp"
(* TIME DESCRPTION *)
ACTIVE (FIND_STRING(strUpper,'TIMEDESC-',1)):
SEND_STRING 0,"'Time Description=',strTemp"
(* LOCATION *)
ACTIVE (FIND_STRING(strUpper,'LOCATION-',1)):
SEND_STRING 0,"'Location=',strTemp"
DEFINE_CONSTANT
(* THE ACTUAL PROGRAM GOES BELOW *)
DEFINE_PROGRAM
(* END OF PROGRAM *)
(* DO NOT PUT ANY CODE BELOW THIS COMMENT *)
DEFINE_VARIABLE
VOLATILE astro_date[15] // date in mm/dd/yyyy format
VOLATILE slong astro_result
VOLATILE double astro_longitude=-80.06
VOLATILE double astro_latitude=33.0
VOLATILE double astro_hrs_from_gmt
VOLATILE Sunrise[8]
VOLATILE Sunset[8]
and then down in your code...
(* And then run this when you want the value. I run it just after setting the system clock at 4-ish AM in the morning. After running the equation Sunrise and Sunset are populated with the correct values for that day. *)
astro_hrs_from_gmt=DST_FLAG-5 // eastern time zone
astro_result=ASTRO_CLOCK(astro_longitude,astro_latitude,astro_hrs_from_gmt,astro_date,Sunrise,Sunset)
The latitude and longitude are for Charleston, SC You have to convert Latitude and Longitude values from minutes and seconds to decimal.
http://www.amx.com/products/i!-TimeManager.asp
(***********************************************************) (* BUTTON_EVENT: Sunrise Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunrise occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel] { PUSH: { SEND_STRING 0,"'Sunrise occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Sunset Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunset occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel] { PUSH: { SEND_STRING 0,"'Sunset occured at ',TIME" } }// full code
(*********************************************************************) (* AMX Corporation *) (* Copyright (c) 2000 - 2005 AMX Corporation. All rights reserved. *) (*********************************************************************) (* please refer to EULA.TXT for software license agreement *) (*********************************************************************) (* *) (* i!-TimeManager (1.0.11) *) (* *) (*********************************************************************) PROGRAM_NAME='i!-TimeManagerTest' (***********************************************************) (*{{PS_SOURCE_INFO(PROGRAM STATS) *) (***********************************************************) (* ORPHAN_FILE_PLATFORM: 1 *) (***********************************************************) (*}}PS_SOURCE_INFO *) (***********************************************************) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE vdvTmEvents = 33001:1:0 dvTmTimeSync = 0:3:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT (* Timeserver protocols *) nProtoNone = 0 nProtoDaytime = 1 nProtoTime = 2 nProtoSNTP = 3 nProtoSNTPBCast = 4 (* Channels *) nTmSunriseChannel = 1 nTmSunsetChannel = 2 nTmDstChannel = 3 nTmTimeChangeChannel = 4 (* Levels *) nTmGmtEffLevel = 1 nTmGmtLevel = 2 nTmLongLevel = 3 nTmLatLevel = 4 (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE (* Timezone *) CHAR dTmTzName[100] CHAR dTmTzDesc[10] DOUBLE dTmTzGmtOffset CHAR strTmTzDstRules[1000] (* Location *) CHAR strTmLocName[100] DOUBLE dTmLocLong DOUBLE dTmLocLat (* Timeserver *) INTEGER nTmTsProtocol INTEGER nTmTsCheckTime CHAR strTmTsServer[100] (***********************************************************) (* SUBROUTINE DEFINITIONS GO BELOW *) (***********************************************************) (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START (***********************************************************) (* Step 1 - Configure the timezone: *) (***********************************************************) // Configure Timezone // Parameter 1: Timezone Name. ex: "Eastern" // Parameter 2: Timezone description. ex: "E%sT" // Parameter 3: Timezone GMT offset in hours. ex: -5.0 dTmTzName = 'Central' dTmTzDesc = 'C%sT' dTmTzGmtOffset = -6.0 // Configure Timezone Rules *) // Parameter 1: Daylight savings string. ex: "None", "US" or custom. // Custom string: "Month" "DayDescription" "Time" "Offset From Std" "Descrption" // "Month": Month name ex: "Apr" // "Time" Time to activate (hh:mm:ss, 24 hour). ex: "02:00:00" // "Offset From Std" Time to offset from GMT (hh:mm:ss, 24 hour). ex: "01:00:00" // "Description" String to replace "%s" with in Timezone description. ex: 'D' // "DayDescription" Day Description. Fixed Date, Last Day Of Week or // First Day of Week Before/After Date // Fixed ex: "15" // Last Day of Week ex: "LastSunday" // First Day of Week Beforer DATE-ex: "Sun<=24" // First Day of Week After DATE-ex: "Sun>=1" strTmTzDstRules = 'US' (***********************************************************) (* Step 2 - Configure Physical Location: *) (***********************************************************) // Configure Physical Location // Parameter 1: Location Name. ex: 'Seattle' // Parameter 2: Location Longitude. ex: -122.33 (>0 == East, < 0 == West) // Parameter 3: Location Latitude. ex: 47.6 (>0 == North, < 0 == South) strTmLocName = 'Dallas' dTmLocLong = -96.76 dTmLocLat = 32.79 // You can find longitude/latitude values and descriptions at: // http://geography.about.com/cs/latitudelongitude/ // http://www.census.gov/cgi-bin/gazetteer // http://www.njdxa.org/landl-lookup-dx.shtml (***********************************************************) (* Step 3 - Configure Time servers: *) (***********************************************************) // Configure Time servers // Parameter 1: Protocol, 0=Disbaled, 1=DayTime(13/udp, 13/tcp), 2=Time(37/udp, 37/tcp), 3=SNTP(123/udp), 4=SNTP Broadcast (137/udp). ex: 2 // Parameter 3: Default Server. ex: 'mytimeserver.mydomain.com'. Leave blank to read from time sevrer file (time/nist_svr.lst) // Parameter 2: Check Time interval in seconds. Use 0 for default (2 hours). ex: 3600 // Parameter 4: Prefered Index of Timeservers in list. ex: 2 // Notes: If parameters 3 is supplied, parameter 4 is ignored // If paramater 3 is an empty string and parameter 4 is 0, a default will be picked from the list is possible //nProtoNone = 0 //nProtoDaytime = 1 //nProtoTime = 2 //nProtoSNTP = 3 //nProtoSNTPBCast = 4 nTmTsProtocol = nProtoSNTP nTmTsCheckTime = 0 strTmTsServer = '' (***********************************************************) (* Alternate Manual Timezone configurations: *) (***********************************************************) // These are shown for example purposes and represent information that is not guaranteed to be correct! // Here is an exmaple configuration for Santiago, Chile which is -4 hours behind GMT and observes Daylight savings starting // on the Saturday on or after October 9th at midnight (jump ahead 1 hour) and the Saturday on or after the 9th of March at midnight (jump back 1 hour) // and describes the time as "hh:mm:ss CST" or "hh:mm:ss CDT" depending on Daylight savings and is located at "33s27, 70w40": // //dTmTzName = 'Santiago' //dTmTzDesc = 'C%sT' //dTmTzGmtOffset = -4.0 //strTmTzDstRules = "'Oct Sat>=9 00:00:00 01:00:00 D',$FF,'Mar Sat>=9 00:00:00 00:00:00 S'" // // AND // //strTmLocName = 'Santiago' //dTmLocLong = -70.67 //dTmLocLat = -33.45 // Here is an exmaple configuration for Sydney, Australia which is +10 hours ahead of GMT and observes Daylight savings starting // on the Last Sunday in October 2:00 AM (jump ahead 1 hour) and the Last Sunday in March at 3:00 AM (jump back 1 hour) // and describes the time as "hh:mm:ss EST" regardless of Daylight savings and is located at "33s52, 151e13": // //dTmTzName = 'Sydney' //dTmTzDesc = 'EST' //dTmTzGmtOffset = 10.0 //strTmTzDstRules = "'Oct LastSun 02:00:00 01:00:00 X',$FF,'Mar LastSun 03:00:00 00:00:00 X'" // // AND // //strTmLocName = 'Sydney' //dTmLocLong = 151.22 //dTmLocLat = -33.86 // Here is the example configuration for London, England which uses GMT and observes Daylight savings starting // on the last Sunday in March at 1:00 AM (jump ahead 1 hour) and the Last Sunday in October at 2:00 AM (jump back 1 hour) // and describes the time as "hh:mm:ss BST" or "hh:mm:ss GMT" depending on Daylight savings and is located at "51n30, 0w10": // //dTmTzName = 'London' //dTmTzDesc = '%s' //dTmTzGmtOffset = 0.0 //strTmTzDstRules = "'Mar LastSun 01:00:00 01:00:00 BST',$FF,'Oct LastSun 02:00:00 00:00:00 GMT'" // // AND // //strTmLocName = 'London' //dTmLocLong = -0.16 //dTmLocLat = 51.50 (***********************************************************) (* THE MODULE CODE GOES BELOW *) (***********************************************************) DEFINE_MODULE 'i!-TimeManagerMod' mdlTM(vdvTmEvents, dvTmTimeSync, (* Timezone *) dTmTzName, dTmTzDesc, dTmTzGmtOffset, strTmTzDstRules, (* Location *) strTmLocName, dTmLocLong, dTmLocLat, (* Timeserver *) nTmTsProtocol, nTmTsCheckTime, strTmTsServer) (***********************************************************) (* THE EVENTS GOES BELOW *) (***********************************************************) DEFINE_EVENT (***********************************************************) (* BUTTON_EVENT: Sunrise Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunrise occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel] { PUSH: { SEND_STRING 0,"'Sunrise occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Sunset Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunset occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel] { PUSH: { SEND_STRING 0,"'Sunset occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: DST Activity Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the DST rules affect a time change with *) (* a non-zero time offset (DST Active) *) (* Channel is release (and turned off) when *) (* the DST rules affect a time change with *) (* a zero time offset (DST Inactive) *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmDstChannel] { PUSH: { SEND_STRING 0,"'DST is now active: ',TIME" } RELEASE: { SEND_STRING 0,"'DST is now inactive: ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Time Change Channel *) (* PURPOSE: Channel is pushed (and pulsed) when *) (* the Time is changed by a communication *) (* with a time server. *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmTimeChangeChannel] { PUSH: { SEND_STRING 0,"'Time adjusted by time server. New Time is ',TIME" } } (***********************************************************) (* LEVEL_EVENT: Effective GMT Offset *) (* PURPOSE: Level is sent whenever the effective GMT *) (* offset is changed. The effective offset *) (* is the real GMT offset with DLS correction*) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmGmtEffLevel] { SEND_STRING 0,"'Effective GMT Offset=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: GMT Offset *) (* PURPOSE: Level is sent whenever the GMT *) (* offset is changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmGmtLevel] { SEND_STRING 0,"'GMT Offset=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: Longitude *) (* PURPOSE: Level is sent whenever the longitude is *) (* changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmLongLevel] { SEND_STRING 0,"'Longitude=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: Latitude *) (* PURPOSE: Level is sent whenever the Latitude is *) (* changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmLatLevel] { SEND_STRING 0,"'Latitude=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* DATA_EVENT: Strings for Sunrise/Sunset *) (* PURPOSE: parse strings for sunrise and sunset *) (***********************************************************) DATA_EVENT[vdvTmEvents] { STRING: { STACK_VAR CHAR strUpper[30] CHAR strTemp[30] CHAR strTrash[30] strUpper = UPPER_STRING(DATA.TEXT) strTemp = DATA.TEXT strTrash = REMOVE_STRING(strTemp,'-',1) SELECT { (* SUNRISE *) ACTIVE (FIND_STRING(strUpper,'SUNRISE-',1)): SEND_STRING 0,"'Sunrise Time=',strTemp" (* SUNSET *) ACTIVE (FIND_STRING(strUpper,'SUNSET-',1)): SEND_STRING 0,"'Sunset Time=',strTemp" (* TIME ZONE NAME *) ACTIVE (FIND_STRING(strUpper,'TIMEZONE-',1)): SEND_STRING 0,"'Timezone=',strTemp" (* TIME DESCRPTION *) ACTIVE (FIND_STRING(strUpper,'TIMEDESC-',1)): SEND_STRING 0,"'Time Description=',strTemp" (* LOCATION *) ACTIVE (FIND_STRING(strUpper,'LOCATION-',1)): SEND_STRING 0,"'Location=',strTemp" } } } (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)Much appreciated!
