Bargragh variable
Is there a command so I can tell a bargraph to change its range that can be sent to it via code?
We are working on a universal panel design for our rooms and the one variable that seems to always change depending on the audio hardware is the volume bar range.
    Why not switch the bar graph to display 0-100% and then do the calculations on the actual volume range to obtain the percentage? This way, the panel doesn't have to change and it is still accurate.
  • viningvining X Member
    Yes, I think it's ^GLH or something. It in AMX_PI for the TPs. I use it to change the progress of currently playing songs.
    I looked in some code and found this:
    if (SoundBSent[1].SBCurLevelChannel != SoundB[1].SBCurLevelChannel)
    	  SEND_COMMAND dvTPSoundBArray,"'^GLH-',itoa(SoundB[1].SBCurLevelChannel),',',itoa(nSBSongLength)"
    	  wait 1
    	       SEND_COMMAND dvTPSoundBArray,"'^GLH-100,',itoa(nSBSongLength)"
    	  SoundBSent[1].SBCurLevelChannel = SoundB[1].SBCurLevelChannel
    Change Slider Values
    // UI - SLIDER CONFIG FOR RANGE
    DEFINE_FUNCTION UI_SliderConfig(INTEGER nAddressID, INTEGER nMaxValue, INTEGER nLowValue, INTEGER nHiValue, INTEGER nInvert)
    	STACK_VAR CHAR cMsg[100];
    	cMsg = "'^BMF-',ITOA(nAddressID),',1&2,%GL',ITOA(nLowValue),','"
    	IF (nHiValue > nMaxValue)
    		cMsg = "cMsg,'%GH',ITOA((nHiValue-nMaxValue)+1),','"
    	ELSE
    		cMsg = "cMsg,'%GH',ITOA(nLowValue),','"
    	cMsg = "cMsg,'%GI',ITOA(nInvert)"
    	SEND_COMMAND TPA, cMsg;
    Thanks all, I'll give these a try.
