MVP-8400
I must be missing something, I have a MVP-8400 that has never been used, it was part of the "demo" system we had to buy when we signed up as dealers... several years ago..
Firmware is v2.30.14.
Problem I am having is setting up to connect via USB. I went to the website and downloaded USB LAN Driver. When I go to install it gets to the point of "searching for dirvers" and just sits there and never moves on. Any suggestions?
But you shouldn't need to touch the USB connection with an 8400. Just connect to it with 802.11. I won't USB for panels unless I absolutely have to (R series remotes).
I would make a quick call to AMX tech support and make sure you can go straight from version 2.3.etc... There may need to be some intervening files that need to be there to make it work.
