Sending IR files... reboot necessary?
in AMX Hardware
Am I loosing my mind, or did the processor used to require a reboot when changing the IR files? I just sent some IR files and was waiting to reboot until after I verified a couple of the new boxes actually had video when I hit one of the buttons out of habit. I was SHOCKED to see the unit respond.
For some reason, I had it in my head that changes to IR files required a processor reboot in the past. Was this the case?
P.S.
This will save me about 3 hours today and it does make me a little happy
P.S.
This opens up a whole new world of possibilities for me
- Amazed by the simple things in life since 1976
As long as you are not losing your mind you should be ok.
Paul
- Chip
P.S. when in doubt, reboot should be your first choice.
Same here. 99% of the time., just loading it is fine. Yet, that 1%, when it didn't work right away, it did after a reboot. I was never able to discern a pattern as to when this happens.
