buffer not populating
Thomas Hayes
Here is odd issue that has me stumped. I created a buffer to read the Rx data from a projector. I just want to see the data for now and later I will change the structure to parse the info I am looking for. I created the buffer in 'define start' as usual and defined the buffer in 'define variable'. The projector is sending data back(the Rx light comes on) but the buffer remains un-populated. I loaded another code that was set up the same way and the buffer populates perfectly. I have tested other buffers in the code and they all seem to work fine also. The only difference in the 2 projector codes that I have is one projector vs 4 projectors( 4 projectors is not working) Am I wrong that you can have a buffer named dvProj4_buffer.
You can use the passback feature if it is a duet module to let you see everything that is being received..
I used : which will not work.
VOLATILE PROJ1_BUFFER[100]
VOLATILE PROJ2_BUFFER[100]
VOLATILE PROJ3_BUFFER[100]
VOLATILE PROJ4_BUFFER[100]
CREATE_BUFFER PROJ1, PROJ1_BUFFER
CREATE_BUFFER PROJ2, PROJ2_BUFFER
CREATE_BUFFER PROJ3, PROJ3_BUFFER
CREATE_BUFFER PROJ4, PROJ4_BUFFER
I changed to this and it works:
CREATE_BUFFER PROJ_1, PROJ1_BUFFER
CREATE_BUFFER PROJ_2, PROJ2_BUFFER
CREATE_BUFFER PROJ_3, PROJ3_BUFFER
CREATE_BUFFER PROJ_4, PROJ4_BUFFER
Seems that studio was unable to see a difference from PROJ1, PROJ2, PROJ3, PROJ4
but was able to see PROJ_1, PROJ_2, PROJ_3, PROJ_4
Go figure.
Nice job on figuring this one out!
