MVP-5200i
AMBAMB Junior Member
Greetings!
Whether probably with MVP-5200i to take off a sound and to connect him on multiroom. I have in view of built in intercom.
Thanks.
    Sorry,
    having a bit of trouble understanding. Please tra\y again.
    It looks to me like he's asking if you can take audio from the VOIP intercom and send it to your multi-room audio system.
  • AMBAMB Junior Member
    DHawthorne wrote: »
    Quite right!
  • ArnoldArnold Junior Member
    MVP-5200i Firmware Upgrade
    Hi to all,
    I just recieved a new MVP-5200i touch panel and I upgrade the firmware from the old Version to the new Version which is V2.60.64.
    Now my Problem is when I finish the update or Upgrade, I notice that the SIP setting from the protected setup has just disappear. I search for the button thinking that it might been relocated since I update the firmware. But I couldn't find it. By the way the MVP-5200i is working just fine. Only that SIP Setting tab I couldn't find.
    Can Somebody help me on this?
    Is it possible to return the original firmware version? or anybody Have an Idea on this scenario.
    Any Ideas is much appreciated.......
    Thanks in Advance.
