Making changes to system
in AMX Hardware
I am very new to VTC and have been asked to learn something about it as in how to add equipment or take equipment out. All I know so far is the touch panel I am dealing with is an AXM-CA10 and the controllers in the system are AXF-BP-16. So far I have loaded TPDesgn3 onto my PC and have connected it to the CA10 and uploaded the program, saved it and ran a simulation. I have the Studio2 software loaded on my PC also but I don't know how to connect it to the controllers in order to make changes to the system. Any ideas?
Any help you guys can give me would be very much appreciated.
Dennis
Dennis
the card frame you have should have an Axcess Master card in the first slot marked 'M' That card has a D-Sub-9 connector. You'll need to connect that to your computer's serial port.
The program will be in there. It's Axcess. Have fun!
If you want to learn how to use all this axcess stuff, you need to get yourself access to the AMX website and look at the technical applications and documentation available. There you will find documentation on the cardframe and all the cards it contains, applications (such as Open Axcess) and documentation for them. One of the things you should probably locate and devour first is an Axcess language tutorial that will give you most of the details of how to manipulate the Axcess controller(archived manuals:software design tools). I looked and it's still there. Also, there is more formal documentation (programmer's guide, etc). You can even find all the old DOS tools, if you're into BDSM.
If you are going to be spending much time on this and particularly if someone (you, perhaps) is being paid to maintain this system, you might consider upgrading the controller to either NI700 or NI900. You can still use all the carframe cards with it (setup the cardframe as a slave). You will recoup the cost of the controller upgrade in about a day -- ok, maybe two.
I have connecte my PC to the master controller with a serial cable but when I try to communicate with the controller it times out and never makes the connection. Any ideas why the connection isn't working.
Wrong Baud Rate
Wrong Cable - try reversing pins 2&3
Wrong Serial Port set in Application
etc
etc
