Help with DirecTV HR21P rs-232
I'm having a little trouble communicating with a DirecTV HR21P receiver via rs-232. This particular receiver has an actual serial port for control, as opposed to using the USB-to-serial adapter method.
I am using the HR21P with an NI-4100. When I attempt to issue commands to the HR21P via telnet and the SEND_STRING command, I see the TX/RX lights light up, but the receiver doesn't respond at all. Does anyone have a example SEND_STRING command for the HR21P (or similar) that I could use to double check my formatting?
I'm a new AMX programmer, so any help is appreciated. Thanks.
