Using while loops within data_events
I've been warned about the use of while loops within the processing of data_events as it supposedly stops mainline execution whilst the loop is operating. Is this true, or am I being had?
Basically I've got a structure set up that I'm keeping device state information in. Occasionally the device will spit a string of commands at me and I need to be able to process them all in the most efficient way.
Currently I've gone down two routes:
In the first case I set up a while loop that iterates through DATA.TEXT removing and processing each command found. This seems to work a treat and is nice and neat, with minimal code.
The alternate option I've explored is passing the received data into a buffer, and processing one event per run off the mainline, if there's anything in the buffer. This is achieved by setting up a call to remove and process the first command currently in the buffer. Doing it this way also *works* (functionally speaking) however it introduces a good 3 second delay into the system.
My question is, is processing all data received (135bytes max length for this device) in one hit when it is received some horribly sacrilegious action in the world of AMX?
All that being said, I don't think there is any problem in using a while loop as you describe it.
I would be interested in seeing the code you are using for the mainline implementation tho. There shouldn't be a 3 second delay with the mainline version unless you are doing a lot of processing.
PROGRAM_NAME='Denon TU-604CI' (* DENON TU-604CI MULTIPLE TUNER ----------------------------- Programmer: Kim Burgess Notes: Requires straight-through RS232 cable. Requires 'Option Setup > RS-232C Power' set to "ON" on the device. Once defined in the DEV array TUNERS[], each device can be controlled by passing their array index to the methods. Alternatively all devices in the system can be send a command by passing tuner_num 0. Communication format: 9600bps,8,N,1,1 135 bytes (max) data length Methods: TU_POWER(tuner_num,action) Change or query the power state of the whole unit TU_SLOT_POWER(tuner_num,slot,action) Change or query the power state of a specific slot *) DEFINE_CONSTANT // Power commands POFF=0 PON=1 STAT=100 (***********************************************************) DEFINE_TYPE STRUCTURE ANALOG_INFO { INTEGER FREQUENCY INTEGER TUNER_BAND INTEGER MODE CHAR NAME[8] // RDS PS CHAR PROGRAM_TYPE[8] // RDS PTY } STRUCTURE DAB_INFO { INTEGER CHAN INTEGER MODE CHAR NAME[8] CHAR LONG_NAME[16] CHAR ENSEMBLE_NAME[16] CHAR PROGRAM_TYPE[16] INTEGER FREQUENCY INTEGER MONO_STEREO INTEGER SIGNAL } STRUCTURE SLOT_INFO { INTEGER POWER INTEGER TYPE INTEGER PRESET ANALOG_INFO ANALOG_STATE DAB_INFO DAB_STATE } STRUCTURE DENON_INFO { CHAR RESPONSE_BUFF[255] INTEGER POWER INTEGER SOURCE SLOT_INFO SLOT_STATE[6] } (***********************************************************) DEFINE_VARIABLE DEV TUNERS[]={TUNER} DENON_INFO TUNER_STATE[LENGTH_ARRAY(TUNERS)] VOLATILE INTEGER TUNER_NUM VOLATILE INTEGER SLOT_NUM VOLATILE INTEGER COUNT (***********************************************************) DEFINE_CALL 'TU_POWER'(INTEGER TUNER_NUM, INTEGER ACTION) STACK_VAR CHAR DV_COMMAND[7] { SWITCH(ACTION) { CASE PON:{DV_COMMAND='ON'} CASE POFF:{DV_COMMAND='STANDBY'} CASE STAT:{DV_COMMAND='?'} } IF(TUNER_NUM>0) SEND_STRING TUNERS[TUNER_NUM],"'PW',DV_COMMAND,$0D" ELSE SEND_STRING TUNERS,"'PW',DV_COMMAND,$0D" } DEFINE_CALL 'TU_SLOT_POWER'(INTEGER TUNER_NUM, INTEGER SLOT_NUM, INTEGER ACTION) STACK_VAR CHAR DV_COMMAND[7] { SWITCH(ACTION) { CASE PON:{DV_COMMAND='ON'} CASE POFF:{DV_COMMAND='STANDBY'} CASE STAT:{DV_COMMAND='?'} } IF(TUNER_NUM>0) SEND_STRING TUNERS[TUNER_NUM],"'PWS',ITOA(SLOT_NUM),DV_COMMAND,$0D" ELSE SEND_STRING TUNERS,"'PWS',ITOA(SLOT_NUM),DV_COMMAND,$0D" } DEFINE_CALL 'PROCESS_RESPONSE'(INTEGER TUNER_NUM) LOCAL_VAR CHAR RESPONSE[32] { RESPONSE=REMOVE_STRING(TUNER_STATE[TUNER_NUM].RESPONSE_BUFF,"$0D",1) SELECT { ACTIVE(FIND_STRING(RESPONSE,'PWON',1)):{TUNER_STATE[TUNER_NUM].POWER=PON} ACTIVE(FIND_STRING(RESPONSE,'PWSTANDBY',1)):{TUNER_STATE[TUNER_NUM].POWER=POFF} ACTIVE(MID_STRING(RESPONSE,3,1)='S'): // String was a slot state return { SLOT_NUM=ATOI(MID_STRING(RESPONSE,4,1)) // Grab the slot number from the received string SELECT { ACTIVE(FIND_STRING(RESPONSE,'PW',1)): // Slot power states { SELECT { ACTIVE(FIND_STRING(RESPONSE,'ON',5)):{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].POWER=PON} ACTIVE(FIND_STRING(RESPONSE,'STANDBY',5)):{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].POWER=POFF} } } } } } } (***********************************************************) DEFINE_START (***********************************************************) DEFINE_EVENT DATA_EVENT[TUNERS] { ONLINE: // Initialize coms and grab the state of the unit { TUNER_NUM=GET_LAST(TUNERS) SEND_COMMAND TUNERS[TUNER_NUM], 'SET BAUD 9600 N,8,1 485 DISABLE' CALL 'TU_POWER'(TUNER_NUM,STAT) CALL 'TU_SLOT_POWER'(TUNER_NUM,1,STAT) } STRING: // Pass the received data into the units processing cue { TUNER_NUM=GET_LAST(TUNERS) TUNER_STATE[TUNER_NUM].RESPONSE_BUFF="TUNER_STATE[TUNER_NUM].RESPONSE_BUFF,DATA.TEXT" } } (***********************************************************) DEFINE_PROGRAM FOR(COUNT=1;COUNT<=LENGTH_ARRAY(TUNERS);COUNT++) // Process any pending repsonse data for each unit in the system { IF(LENGTH_STRING(TUNER_STATE[COUNT].RESPONSE_BUFF)>0) CALL 'PROCESS_RESPONSE'(COUNT) }My mainline in my master axs then is just doing a couple of button updates to my panel.I don't write code like that because I don't want a loop to continuously run in mainline when 99.99% of the time the buffer will be empty. Why not call your function directly from the string event once you have a full command string?
Paul
Btw, you can use invariants to make sure your while loop always terminates.
Calling the function from the string event is not possible as multiple command can be passed in on the one string, and as such I'd have to use a while loop within that function to loops through each command, which is essentially what I'm doing at the moment, but with the loop within data_event.
DEFINE_EVENT DATA_EVENT[TUNERS] { ONLINE: // Initialize coms and grab the state of the unit { TUNER_NUM=GET_LAST(TUNERS) SEND_COMMAND TUNERS[TUNER_NUM], 'SET BAUD 9600 N,8,1 485 DISABLE' CALL 'TU_POWER'(TUNER_NUM,STAT) CALL 'TU_SLOT_POWER'(TUNER_NUM,ALL,STAT) CALL 'TU_SELECT_SOURCE'(TUNER_NUM,STAT) } STRING: // Process the received data to update the units state info { TUNER_NUM=GET_LAST(TUNERS) WHILE(FIND_STRING(DATA.TEXT,"$0D",1)) // Occasionally multiple commands are recieved so make sure we break them up and process them all { RESPONSE=REMOVE_STRING(DATA.TEXT,"$0D",1) // Grab the front most received command RESPONSE=LEFT_STRING(RESPONSE,LENGTH_STRING(RESPONSE)-1) // Remove the trailing carridge return SLOT_NUM=ATOI(MID_STRING(RESPONSE,4,1)) // Grab the slot number from the received string SWITCH(LEFT_STRING(RESPONSE,2)) { CASE 'PW': // Power states { SELECT { ACTIVE(RESPONSE='PWON'):{TUNER_STATE[TUNER_NUM].POWER=PON} ACTIVE(RESPONSE='PWSTANDBY'):{TUNER_STATE[TUNER_NUM].POWER=POFF} ACTIVE(FIND_STRING(RESPONSE,'ON',5)):{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].POWER=PON} ACTIVE(FIND_STRING(RESPONSE,'STANDBY',5)):{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].POWER=POFF} } } CASE 'SI': // Source select { TUNER_STATE[TUNER_NUM].SOURCE=ATOI(RIGHT_STRING(RESPONSE,1)) } CASE 'TU': // Tuner type { SWITCH(RIGHT_STRING(RESPONSE,2)) { CASE 'AN':{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].TYPE=AN} CASE 'XM':{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].TYPE=XM} CASE 'HD':{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].TYPE=HD} CASE 'DA':{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].TYPE=DA} CASE 'NO':{TUNER_STATE[TUNER_NUM].SLOT_STATE[SLOT_NUM].TYPE=NO} } } } } } }The first thing I'd do is test to see how many times your loop is actually running. Create an integer variable, and immediately before the loop starts, set it to 0. Then make the first line of your while loop nInteger++. Watch your integer in debug and see what happens. If it only increments a little bit, then your loop is probably fine.
If that shows some strange variation, the next thing I would try is declaring a stack_var and setting it equal to data.text, then using it for the duration of the loop. Sometimes data.text does strange things, especially when you start removing characters from it.
You might also try putting the following line in your define_program section
If define_program is running correctly, that will output the line "Heartbeat" to diagnostics every half a second. You can watch that during the while loop to see if it is affected at all.
J
if (debug) { MLcount++ wait 10 { send_string 0,"'HEARTBEAT>>>',itoa(MLcount)" MLcount = 0 } }This would give you an ideal of how taxing your code is to the processor.
I think you answered your own question, no?
Paul
@kbeattyAMX
It's not actually a module, this is just an include as the place I'm working at doesn't like modules due to their 'lack of expandability'. If I had my way I'd be using them as they are there for a (good) reason, however I'm the new guy so I'm just trying to keep to the already established coding styles as it makes things easier for everyone
Thanks for cluing me in to that one, PhreaK...
- Chip
Maybe you should just write the code the way you want to write it and install an all-caps font on your boss's computers.
http://www.dafont.com/barrelhouse-all-cap.font
otherwise, I don't
You can increase the size of the font if your eyesight is not great. Using all caps is harder to read due to the lack of word shape clues.
Paul
