Anyone NOT Using R4 Queing Module?
Greetings,
I'm curious if anyone has been using the R4 without the queing module that has been made available by AMX.
Ditto. I just remembered that I've got a couple of systems in the wild using R4's. Didn't use the queue module with them either and they've been rock solid. Aside from a "normal" amount of channel feedback, I'm only sending half a dozen feedback strings to the panel though.
Would several variable text commands of thirty+ caracters kill the R4?
I have both used it and not and the only difference I have seen is that with it in feedback is a little slower to show up on the panel due to the buffering. My first R4 job was with a Kaleidescape system and I had lots of meta data going to the R4 and it seemed to do quite well.
Paul
I guess I finally answered my own question.
