Panasonic PT-D7700 Code
I have a project where I replaced 2 Barcos with the Panasonics. I have gotten them all connected up, addressed and switched into RS-422 mode coming off of a single AXC-232. I am able to send both commands but they just reply in errors. I am having a hard time understanding their manual though.
I have attached the code book because it is way easier then describing it. What I am currently sending it is:
$02, $01,';',QPW,$03.
It just sends back a string that is:
$02,$01,$FF,$03 (I can't quite remember exactly what it is but its really close to that. Basically the variable it is sending back is $FF.
Now in the Basic format, it says to send the STX AD (proj addy) ; command : prams etx. I am not sure though what the AD is. If I send an ascii 'AD' it doesn't respond at all to what string I send. I thought it may have been some Hex character, but I am not sure and haven't ever seen that.
Thanks for the help in advance!
Ryan
Ryan
Great projectors with a very useful protocol.
Ok, I will, give that a try.
thanks,
Ryan
SEND_STRING dvPROJECTOR,"$02,'PON',$03" // Projector Power On
SEND_STRING dvPROJECTOR,"$02,'POF',$03" // Projector Power Off
But this is only if you are connecting 1 projector to the AMX serial port. If you dasiy chain the projectors and need addressing for each projector, then you need to address part of the string.
