AMX's Runco 710 Module? Problems?
Anyone running AMX's Runco module for the 710? I've been running through getting our new office setup, basically verifying functions on a product, then sending up for install.
I was checking through the 710 and installed just the AMX module on my NI-3000. Works fine as expected. Go back a couple hours later and the master is locked up. Haven't looked too much into it as I'll probably write my own code, but it seems that with only the module installed (virtual TP) that the master will lock up randomly. Even without the projector hooked up.
Just curious if anyone else ran into this, or if anyone wanted to check it out for themselves... If someone can find a quick fix I'll use the module.. If not I'll write my own..
Kevin D.
Kevin D.
One disclaimer tho: I am using this module with a Vidikron Model 40. They are supposed to be the same thing, but who knows for sure.
Kevin D.
