Timeline efficiency
I have a timeline that, at various times, I need to run through one time. Which is the more processor efficient way to handle this?
OPTION A:
Every time I need the timeline to run, kill it if it is running, then use TIMELINE_CREATE with the TIMELINE_ONCE parameter.
OR
OPTION B:
Create the timeline once with the TIMELINE_REPEAT parameter. Pause the timeline when I don't need it. When I do need it to run, use TIMELINE_SET to 0, and restart the timeline, pausing after it runs through one time.
I am using the timeline to refresh dynamic images that the user can cycle through, so I may not need the timeline for a long time (which makes me lean to Option A). When I do need it, it will probably be used repeatedly while the user pages through the images (which makes me lean to Option B).
    Option A. A paused timeline is still using resources.
  • ColzieColzie Senior Member
    With Option A, when the user touches "Page Down" 10 times in 2 seconds, the timeline will be created and destroyed a lot of times very quickly. Performance should still be okay? I'm not familiar with what timeline_create actually does behind the scenes.
  • yuriyuri Junior Member
    why do you need a timeline?
    If you need it to refresh a dynamic image, there is no need to use a timeline :p
  • ondrovicondrovic Junior Member
    I agree with yuri just make a call or function to update the dynamic images when the page is changed
    I am using the timeline to space out the RMF commands to the panel.
    Here is (some of) the relevant code:
    define_variable
    volatile long l_tl_icons[] = {400, 400, 400, 400, 400, 400, 400, 400}
    define_event
    data_event[dv_MASTER]
    	online:
    		timeline_create (TL_ICONS, l_tl_icons, length_array (l_tl_icons), TIMELINE_RELATIVE, TIMELINE_REPEAT)
    timeline_event[TL_ICONS]
    	stack_var integer i, iOffset;
    	i = timeline.sequence
    	iOffset	= fn_get_offset ()
    	send_command dv_TPs, "'^RMF-FAV', itoa (i), ',%F', u_db[i + iOffset].s_icon"
  • GregGreg Junior Member
    Instead of using the push put it on the release with a named wait. On a push event stop the wait. It'd add a little latency, but keep it from flooding.
    button_event[dvTP, nSomething]
    push:
    cancel_wait "DoSomething"
    release:
    wait 5 "DoSomething"
    // Something
