Keypad on panel
If i create a keypad that I want to use to store number data would it look like this?
DEFINE_EVENT
Button_Event[dvPanel,100]
Push:
SEND_COMMAND dvPanel,"'AKEYP'"
This pops up my keypad but how do i store each button i hit on the keypad as a variable?
Buttonpushes = (Get_last,buttonpushes)
1
14
147
1478
14789
etc...
DEFINE_EVENT
Push:
1
14
147
1478
14789
etc...
Once you have the text, you can break it apart as needed of convert it to numbers using ATOI or similar.
Is this correct?
DEFINE_EVENT
BUTTON_EVENT[dvPanel,69]
Push:
Data_Event[dvPanel]
Online:
Wait 25
Clear_Weather_Data()
STRING:
LOCAL_VAR CHAR cBuffer[10]
cBuffer = DATA.TEXT
SELECT
ACTIVE (FIND_STRING(cBuffer,'KEYP',1)):
REMOVE_STRING(cBuffer,'KEYP-',1)
ZIP_NUM = ("cBuffer")
cZip = ZIP_NUM
ACTIVE (FIND_STRING(cBuffer,'KEYB',1)):
REMOVE_STRING(cBuffer,'KEYB-',1)
