Connection Problem with NI-4000 VxWorks 5.5.1 Ftp Server
Hi,
I'm having a trouble in downloading files from NI-4000 via FTP. I've used Filezilla and Core FTP and used administrator password command together with the IP adress and port 21. It seems like the authentication is successful but I am automatically taken to doc:user folder where the IR files are located. And I cannot go to up or root directory and/or cannot see or download the system files.
I'm wondering if there is another password than used above to access these files since I did not change the default passwords. Or is there a master password to bypass this check or reset the password so that I can see and download system files without problems.
I really apprecite any comments and support on this issue. Many thanks.
