Max size of variable for debugging?
Hey, I have my debugger open and I'm trying to change the value of a variable, and it appears to have worked, but the program is still behaving as though the variable is empty. When I opened my Diagnostics I see this:
The packet needed by ICSP to change a variable from the debugger appears to have some maximum length or the checksum doesn't calculate properly. What is the cutoff size, I'm curious? Anyone know?
The variable that I am trying to change is a volatile CHAR array with max size 2000. If I change the size of the array to 20, it works as expected.Line 4 (09:36:27):: ICSPTCPRx35::ProcessICSPPacketRX checksum error MsgID=0251 (rx=00, expected=02) Cmd=0102
Can you not pump in numbers to find the max?
Paul
I am busy writing a program too...:)
