Proper Use of SET_VIRTUAL_LEVEL_COUNT
Greetings,
I am working on a module for controlling an audio equalizer. I would like to to have 31 levels on my UI and within the module for adjusting the equalizer.
What is the proper use of the SET_VIRTUAL_LEVEL_COUNT keyword?
In what section of the module and/or the main program should it go?
Thanks.
  • banobano Senior Member
    Greetings,
    Thanks.
    I would place it in the online section of the data event for the virtual device, same place I put set_virtual_channel_count
    bano wrote: »
    I have heard stories of having to put it in the main program as well as the module. Have you had any experiences like that?
    Thanks.
    Thanks.
    Put it in the DEFINE_EVENT - ONLINE section.
  • a_riot42a_riot42 AMX Wizard
    I've been putting it in define_start and haven't had any issues.
    Paul
    a_riot42 wrote: »
    Does it make any difference whether it is in the module or the main program?
    I wouldn't think so. Either way the command will execute within a few seconds of each other regardless of where it goes. If it refers to a device in a module then I would put in the module just for OOP reasons, but I can't imagine it makes any difference, but I haven't experimented extensively.
    Paul
