Image of a fader
You need to have a separate file with just the transparent parts defined by a black and white image. Look in \Program Files\Common Files\AMXShare\G4SupportFiles\__system\graphics\sliders or
\Program Files\Common Files\AMXShare\G4SupportFiles\__system\graphics\cursors for examples.
For instance the Hand cursor has a file 'hand.png' and another 'hand_alpha.png' that defines the transparent parts. It works similarly for sliders. Take a look and see if you can figure it out. You basically need 3 more files with the same name with an _alpha on the end defining the transparency.
I wanted it to be partly transparent (shadow). Which isn't possible this way (or is it?). Well I'm gonna try a few things today, I'll let you know if I manage to work it out in a good way. -
If you go to:
C:\Program Files\Common Files\AMXShare\G4SupportFiles\__system\graphics\sliders
You can add your own sliders but they require 12 seperate image files. I added one called earth which is a picture of the earth (the first .png pic I came across). I made 12 images, you'll see what you'll need when you see the other sliders in the file.
I first attempted this with top, bottom, right, left..... all cropped accordingly but they came out flat shapes and not the image on the earth so I made all 12 picsw the same of the entire earth.
You then need to open up the draw.xma file and scroll until you find this section:<sliderData> <sliderFamily> <name>Sliders</name> <member>Ball</member> <member>Earth</member> <member>Line -S</member> <member>Line -M</member> <member>Line -L</member> <member>Circle -S</member> <member>Circle -M</member> <member>Circle -L</member> <member>Precision</member> <member>Windows</member> </sliderFamily> <slider> <name>Ball</name> <baseFile>Ball</baseFile> <multiColor>1</multiColor> <incRepeat>1</incRepeat> <minSize>15</minSize> <fixedSize>15</fixedSize> </slider> <slider> <name>Earth</name> <baseFile>Earth</baseFile> <multiColor>1</multiColor> <incRepeat>1</incRepeat> <minSize>24</minSize> <fixedSize>15</fixedSize> </slider>
You can see above that I added Earth in the family and then created a seperate entry for it, click save and open TPD4 and it should appear in the drop down and the pic should display.
My display actually had 2 earths since I made all the pics the same full image but maybe with a little experimenting I could make some cool sliders but that's another day since my curiosity is now satisfied.
