How are you terminating cables at the master?
in AMX Hardware
I am curios how other companies terminate cables at the master? We generally use Cat5 for everything ? RS-232, IR, I/O, and Relays. Trying to run all of these cables into the rack directly to the master creates a real mess. We may only use a couple conductors from each Cat5 cable. So we could end up with 6 or 8 Cat5's just tied into the IR ports.
We have started using 66 punch-down blocks outside the racks. All of the control ports are landed on these punch-down blocks and then the cables are punched down here. Do most installers try to terminate all of their control cables directly to the master?
As far as rack termination, I use ICC 110 punch blocks. I generally punch through all of the ports of the master including those which are not in use at the time of installation. If equipement is added, it just has to be run to the block. My West Penn 452 that I use for 232 can be punch into these blocks.
"cat 5 BAAAAD, CAT 5... BAAAAD!"
From the golden age of napster bashing:
http://www.youtube.com/watch?v=VIuR5TNyL8Y
Also, in other news...
"BEER.... GOOOOOOD."
"Fire, BAD"
