Animations
Greetings,
I have an MVP-7500 and am using the Blue Steel template. I have resized buttons from the 17" button graphics files for the current sources. Now I am changing a source, and what to import a different animated button, but cannot seems to import it in the correct size without clipping the animation. Can anyone point me in the right direction here? The most frustrating part is knowing that I succeeded in doing this before, and can't seem to make it work now!
Dave Ohlendorf
ACE Programmer
  • Spire_Jeff
    Is the animation designed for a 17" panel? if so, you could create a blank 17" TPD file, import the animation and then save as an MVP-7500 file. After that, you should be able to copy the button and paste it into your touchpanel file.
    Hope this helps,
