Rotel rt-06
Do any one have a sample of RS232 code to controll Rotel tuner RT-06.
Any other Rotel tuner code ??
    Rotel RT1080
    Here is a module, someone wrote a long time ago... You should be able to get an idea how to control this tuner from this code. Hopefully the protocol is the same..
    MODULE_NAME='Rotel RT1080' (DEV dvTuner, DEV vdvTuner)
    (*{{PS_SOURCE_INFO(PROGRAM STATS)                          *)
    (*  FILE CREATED ON: 07/22/2002 AT: 11:10:23               *)
    (*  FILE_LAST_MODIFIED_ON: 08/14/2002 AT: 14:28:20         *)
    (*  ORPHAN_FILE_PLATFORM: 1                                *)
    (*}}PS_SOURCE_INFO                                         *)
    (* System Type : Netlinx                                   *)
    (* REV HISTORY:                                            *)
    (*          DEVICE NUMBER DEFINITIONS GO BELOW             *)
    DEFINE_DEVICE
    dvTuner       Real Tuner RS232 Port
    vdvTuner      Virtual Tuner Device
    (*               CONSTANT DEFINITIONS GO BELOW             *)
    DEFINE_CONSTANT
    FEEDBACK1           = 1
    TUNER_QUEUE         = 2
    TunerQueueMAX       = 10
    (* ROTEL TUNER  *)
    MAX_PRESETS         = 30
    TUNER_DIRECT        = 10
    TUNER_UP            = 12
    TUNER_DN            = 13
    TUNER_SAVE          = 14
    TUNER_BAND          = 15
    TUNER_REFRESH       = 16
    (*              DATA TYPE DEFINITIONS GO BELOW             *)
    DEFINE_TYPE
    DEFINE_VARIABLE
    CHAR TunerQueue[TunerQueueMAX][20]
    INTEGER TunerQueueHead
    INTEGER TunerQueueTail
    INTEGER TunerQueueIsReady
    INTEGER TunerQueueHasItems
    INTEGER nPresetLock
    FLOAT fTEMP
    FLOAT fFrequency
    CHAR cTunerBuffer[1000]
    INTEGER nTunerSend
    CHAR cStationInfo[20]
    INTEGER nTunerBand // 32 = FM 0 = AM
    INTEGER nCurPreset
    LONG lTimeArray[1]
    (*               LATCHING DEFINITIONS GO BELOW             *)
    DEFINE_LATCHING
    (*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
    DEFINE_MUTUALLY_EXCLUSIVE
    (*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
    (* EXAMPLE: DEFINE_FUNCTION <RETURN_TYPE> <NAME> (<PARAMETERS>) *)
    (* EXAMPLE: DEFINE_CALL '<NAME>' (<PARAMETERS>) *)
    DEFINE_CALL 'CHECK TUNER QUEUE'
      IF (TunerQueueHasItems AND TunerQueueIsReady)
        OFF[TunerQueueIsReady]
        IF (TunerQueueTail = TunerQueueMax)
          TunerQueueTail = 1
        ELSE
          TunerQueueTail = TunerQueueTail + 1
        IF (TunerQueueTail = TunerQueueHead)
          OFF[TunerQueueHasItems]
        SEND_STRING dvTuner, TunerQueue[TunerQueueTail]
        WAIT 1 'TUNER1 QUEUE'
          ON[TunerQueueIsReady]
    DEFINE_CALL 'ADD TO TUNER QUEUE' (CHAR cCMD[])
      IF (TunerQueueHead = TunerQueueMAX)
        IF (TunerQueueTail <> 1)
          TunerQueueHead = 1
          TunerQueue[TunerQueueHead] = cCMD
          ON[TunerQueueHasItems]
      ELSE IF (TunerQueueTail <> TunerQueueHead + 1)
        TunerQueueHead = TunerQueueHead + 1
    DEFINE_FUNCTION CHAR[6] SEND_TO_TUNER(INTEGER nFUNC)
    LOCAL_VAR cSTRING[6]
      cSTRING = "$FE,$03,$21,$10" // STRING HEADER
      SWITCH(nFUNC)
        CASE 0: // zero button
          cSTRING = "cSTRING,$07,$3B"
        CASE 1: // one button
          cSTRING = "cSTRING,$0F,$43"
        CASE 2: // two button
          cSTRING = "cSTRING,$00,$34"
        CASE 3: // 3 button
          cSTRING = "cSTRING,$01,$35"
        CASE 4: // 4 button
          cSTRING = "cSTRING,$02,$36"
        CASE 5: // 5 button
          cSTRING = "cSTRING,$03,$37"
        CASE 6: // 6 button
          cSTRING = "cSTRING,$0E,$42"
        CASE 7: // 7 button
          cSTRING = "cSTRING,$04,$38"
        CASE 8: // 8 button
          cSTRING = "cSTRING,$05,$39"
        CASE 9: // 9 button
          cSTRING = "cSTRING,$06,$3A"
        CASE TUNER_DIRECT: // direct button
          cSTRING = "cSTRING,$27,$5B"
        CASE 11: // preset tune button
          cSTRING = "cSTRING,$09,$3D"
        CASE TUNER_UP: // preset + button
          cSTRING = "cSTRING,$19,$4D"
        CASE TUNER_DN: // preset - button
          cSTRING = "cSTRING,$18,$4C"
        CASE TUNER_SAVE: // MEMORY SET BUTTON
          cSTRING = "cSTRING,$0D,$41"
        CASE TUNER_BAND: // TOGGLE BAND
          cSTRING = "cSTRING,$0B,$3F"
        CASE TUNER_REFRESH: // GET UPDATED STATION INFO
          cSTRING = "cSTRING,$FF,$33"
      RETURN cSTRING
    DEFINE_CALL 'TUNER PRESET' (INTEGER nPreset)
      IF(!nPresetLock)
        IF(nPreset>9 && nPreset<=MAX_PRESETS)
          CALL 'ADD TO TUNER QUEUE' ("SEND_TO_TUNER(nPreset/10)")
          CALL 'ADD TO TUNER QUEUE' ("SEND_TO_TUNER(nPreset%10)")
        ELSE IF(nPreset>0 && nPreset<=9)
          CALL 'ADD TO TUNER QUEUE' ("SEND_TO_TUNER(nPreset)")
          IF(nPreset<4) // TUNER WILL WAIT 3 SECS FOR A SECOND DIGIT IF POSSIBLE
            TIMELINE_PAUSE(TUNER_QUEUE)
            ON[nPresetLock]
            WAIT 30 'PRESET LOCKOUT'
              TIMELINE_RESTART(TUNER_QUEUE)
              OFF[nPresetLock]
    (*                STARTUP CODE GOES BELOW                  *)
    DEFINE_START
    TunerQueueHead     = 1
    TunerQueueTail     = 1
    TunerQueueIsReady  = 1
    TunerQueueHasItems = 0
    CREATE_BUFFER dvTuner,cTunerBuffer
    lTimeArray[1] = 100
    TIMELINE_CREATE(FEEDBACK1,lTimeArray,1,TIMELINE_RELATIVE,TIMELINE_REPEAT)
    lTimeArray[1] = 300
    TIMELINE_CREATE(TUNER_QUEUE,lTimeArray,1,TIMELINE_RELATIVE,TIMELINE_REPEAT)
    (*                THE EVENTS GOES BELOW                    *)
    DEFINE_EVENT
    DATA_EVENT[dvTuner]
      ONLINE:
        SEND_COMMAND dvTuner,"'SET BAUD 4800,N,8,1 485 DISABLE'"
        SEND_COMMAND dvTuner,"'CHARD-20'"
    TIMELINE_EVENT[FEEDBACK1]
    LOCAL_VAR I
      //BONUS CHANNEL FEEDBACK
      //PRESET STATES
      FOR(I=1;I<=MAX_PRESETS;I++)
        [vdvTuner,I] = nCurPreset = I
      //TUNER BAND
      //FM
      [vdvTuner,31] = nTunerBand
      //AM
      [vdvTuner,32] = (!nTunerBand)
    TIMELINE_EVENT[TUNER_QUEUE]
    DATA_EVENT[vdvTuner]
      COMMAND:
      LOCAL_VAR cMsg[42]
        cMsg = DATA.TEXT
        SELECT
          ACTIVE(FIND_STRING(cMsg,'BAND=',1)):
            REMOVE_STRING(cMsg,'BAND=',1)
            SELECT
              ACTIVE(FIND_STRING(cMsg,'AM',1)):
                IF(nTunerBand)
                  nCurPreset = 0  // THESE BECOME UNKNOWN
                  fFrequency = 0
                  CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_BAND))
              ACTIVE(FIND_STRING(cMsg,'FM',1)):
                IF(!nTunerBand)
                  fFrequency = 0
              ACTIVE(FIND_STRING(cMsg,'T',1)):
                fFrequency = 0
          ACTIVE(FIND_STRING(cMsg,'BAND?',1)):
            IF(nTunerBand)
              SEND_STRING vdvTuner,"'BAND=FM'"
            ELSE
              SEND_STRING vdvTuner,"'BAND=AM'"
          ACTIVE(FIND_STRING(cMsg,'TUNE=',1)):
            REMOVE_STRING(cMsg,'TUNE=',1)
            SELECT
              ACTIVE(FIND_STRING(cMsg,'+',1)):  // TUNE +
                fFrequency = 0
                CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_UP))
              ACTIVE(FIND_STRING(cMsg,'-',1)):  // TUNE -
                fFrequency = 0
                CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_DN))
              ACTIVE(FIND_STRING(cMsg,'.',1)):  // TUNE FM
                IF(!nTunerBand)
                fTEMP = ATOF(cMsg)
                IF(LENGTH_STRING(cMsg) >= 4) // CHECK FOR VALID FM RANGE
                  IF((LENGTH_STRING(cMsg)= 5) && (fTEMP <= 108.0))
                    nCurPreset = 0
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_DIRECT))
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(1))
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(ATOI("cMsg[3]")))
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(ATOI("cMsg[5]")))
                    fFrequency = fTEMP
                  ELSE IF((LENGTH_STRING(cMsg)= 4) && (fTEMP >= 87.5))
                    nCurPreset = 0
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(ATOI("cMsg[1]")))
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(ATOI("cMsg[2]")))
                    CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(ATOI("cMsg[4]")))
                    fFrequency = fTEMP
              ACTIVE(1):  // TUNE AM
                IF(nTunerBand)
                fTEMP = ATOF(cMsg)
                IF((LENGTH_STRING(cMsg) = 3) && (fTEMP <= 990) && (fTEMP >= 580))
                  nCurPreset = 0
                  fFrequency = fTEMP
                ELSE IF((LENGTH_STRING(cMsg) = 4) && (fTEMP <= 1710) && (fTEMP >= 1000))
                  nCurPreset = 0
                  fFrequency = fTEMP
          ACTIVE(FIND_STRING(cMsg,'TUNE?',1)):
            SEND_STRING vdvTuner,"'TUNE=',FTOA(fFrequency)"
          ACTIVE(FIND_STRING(cMsg,'PRESET=',1)):
            REMOVE_STRING(cMsg,'PRESET=',1)
            SELECT
              ACTIVE(FIND_STRING(cMsg,'+',1)):  // PRESET +
                IF(nCurPreset<MAX_PRESETS)
                  nCurPreset++
                ELSE
                  nCurPreset=1
                CALL 'TUNER PRESET' (nCurPreset)
                SEND_STRING vdvTuner,"'PRESET=',ITOA(nCurPreset)"
                fFrequency = 0
              ACTIVE(FIND_STRING(cMsg,'-',1)):  // PRESET -
                IF(nCurPreset>1)
                  nCurPreset--
                ELSE
                  nCurPreset=MAX_PRESETS
                fFrequency = 0
              ACTIVE(1):  // GOTO PRESET
                nCurPreset=ATOI(cMsg)
                IF(nCurPreset>MAX_PRESETS)  // CHECK OUR RANGE
                IF(nCurPreset<1)
                  nCurPreset=1
                fFrequency = 0
          ACTIVE(FIND_STRING(cMsg,'PRESET?',1)):  // CHECK PRESET #
            IF(nCurPreset)
            ELSE
              SEND_STRING vdvTuner,"'PRESET=UNKNOWN'"
          ACTIVE(FIND_STRING(cMsg,'STATION?',1)):  // GET STATION DATA FROM TUNER
            SEND_STRING vdvTuner,"'STATION=',cStationInfo"
          ACTIVE(FIND_STRING(cMsg,'STORE=',1)):  // STORE CURRENT STATION AS PRESET #
            REMOVE_STRING(cMsg,'STORE=',1)
            IF(nCurPreset<1)
              nCurPreset=1
            CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_SAVE))
    (*            THE ACTUAL PROGRAM GOES BELOW                *)
    DEFINE_PROGRAM
    WAIT 50 'POLL TUNER INFO'
      CALL 'ADD TO TUNER QUEUE' (SEND_TO_TUNER(TUNER_REFRESH))
    IF(LENGTH_STRING(cTunerBuffer))
    LOCAL_VAR nPos, nLen, nFDSearch, cMsg[42], cStationTemp[20]
      nPos = FIND_STRING(cTunerBuffer,"$FE",1)
      nLen = LENGTH_STRING(cTunerBuffer)
      IF(nPos)
        // Drop any leading garbage
        cTunerBuffer=RIGHT_STRING(cTunerBuffer,nLen-nPos+1)
        IF(FIND_STRING(cTunerBuffer,"$FE",2)) (* IS THERE MORE THAN 1 MESSAGE IN THE BUFFER *)
          cMsg = LEFT_STRING(cTunerBuffer,FIND_STRING(cTunerBuffer,"$FE",2)-1)
          REMOVE_STRING(cTunerBuffer,cMsg,1)
        ELSE IF(nLen > cTunerBuffer[2]) (* DO WE HAVE A WHOLE MESSAGE YET *)
          cMsg = cTunerBuffer
          // we already checked for the start of another message so we don't need anything in the buffer now
          CLEAR_BUFFER cTunerBuffer
        IF(LENGTH_STRING(cMsg))
          IF(LENGTH_STRING(cMsg)>cMsg[2])
            nFDSearch = 1
            WHILE(FIND_STRING(cMsg,"$FD",nFDSearch))
              nFDSearch = FIND_STRING(cMsg,"$FD",nFDSearch)
              cMsg[nFDSearch] = cMsg[nFDSearch] + cMsg[nFDSearch+1]
              cMsg = "LEFT_STRING(cMsg,nFDSearch),RIGHT_STRING(cMsg,LENGTH_STRING(cMsg)-nFDSearch-1)" (* DROP ONE FROM THE MIDDLE *)
              nFDSearch++
            IF((cMsg[3] = $21) && (cMsg[4] = $20) && (LENGTH_STRING(cMsg) = 21))
              IF(nTunerBand <> (cMsg[7] & 32)) // IF THE BAND CHANGED, REPORT IT
                IF(nTunerBand)
                ELSE
              nTunerBand = (cMsg[7] & 32)
              cStationTemp = MID_STRING(cMsg,10,9)  // ROTEL TUNER SENDS $1E INSTEAD OF LOWER CASE 'z'
              IF(cStationTemp[9] = $1E)
                cStationTemp[9] = 'z'
              IF(cStationTemp<>cStationInfo)
                cStationInfo=cStationTemp
          CLEAR_BUFFER cMsg
    (*                     END OF PROGRAM                      *)
    (*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
    Here's a large pdf with a whole bunch of Rotel rs-232. perhaps one of them will work for you.
  • VladaPUBVladaPUB as it is !
    ericmedley wrote: »
    Great file, i have it also, it is completly ok except device ID. It is 23, everything other is OK and it is working.
    EXAMPLE
    SEND_STRING dvROTEL,"$FE,$03,$23,$10,$01,$37" //power on
    SEND_STRING dvROTEL,"$FE,$03,$23,$10,$02,$38" //power off
    SEND_STRING dvROTEL,"$FE,$03,$23,$10,$08,$3E" //tune up
    SEND_STRING dvROTEL,"$FE,$03,$23,$10,$09,$3F" //tune down
    1. $FE .......................................START
    2. $03 ........................................COUNT
    3. $23 ........................................DEVICE ID
    4. $10 ........................................TYPE OF COMMAND
    5. $09 ........................................COMMAND
    6. $3F ........................................CHECKSUM (2+3+4+5 in hex)
    Commands you can use from PDF file !
