Send graphic to NXD-CV5
Hi!
I have problem with NXD-CV5. I make project on TP Design 4, but I can`t send to panel. Connect with controler is ok, if select "send to panel" in open window CV5 not present. :(. What can I do? If create project for MVP-8400 and send to panel is okay.
1. TPDesign4 version 2.9
2. NXD-CV5 firmware version 2.60.27
  • Marc Scheibein
    Marc Scheibein Junior Member
    Please check that you have TPDesign4 v2.9 Build 592 installed. There was an change in the device ID of the NXD-CV5, which is not identified with earlier TPD4 versions.
  • MaratGill
    MaratGill Junior Member
    I find problem. I reinstall Windows XP and install AMX tool (TPDesign 4 ver 2.9, NetLinx and other) programms. I think what amx dll`s had corrupt.
    Thanks for your answer!
