Can I not declare a device array and pass it to a module?
PROGRAM_NAME='module'
DEFINE_DEVICE
dvTP1 	= 	10001:1:0
dvTP2	=	10002:1:0
DEFINE_VARIABLE
DEV devTPs [ ] = {dvTP1, dvTP2}
DEFINE_MODULE 'module1' ABC123 (devTPs)
The error I am getting is this:
ERROR: Dimension mismatch: [0] vs. [1]
ERROR:Type or dimension conflict for [ABC123]
When trying to create a module with just a single device, I get a different error:
DEFINE_DEVICE
dvDEV	=	5001:1:0
DEFINE_MODULE 'module1' ABC123(dvDEV)
Brings up this error:
ERROR:Cannot convert type [DEV] to [INTEGER]
  • filpeefilpee Junior Member
    is the variable declared as an array in your module?
    module_name ="MyModule" (dev tpArray[])
    that should work for you.
  • AvophileAvophile Junior Member
    Thanks, filpee!
    MODULE_NAME='module1' (dev devtps [ ])
    ...solved my first problem.
    Any idea about the second error I am getting when attempting to pass a single device as a parameter to the module?
    Nevermind... similar deal.
    The module wanted the device declared like so:
    MODULE_NAME='module1'(dev dvDEV)
