Remote files and TP preview
Hi guys, first of all, sorry for eventual mistakes... my natural language is Italian.
I'm a senior programmer (C/C++, PHP, MySQL, Industrial Automation etc.) but new to AMX System and this forum.
Two quickly questions:
- Is it supported the syntax '\\<hostname or IP>\<directory>\<filename>' in FilePath of FILE_OPEN()?
Hostname/IP refers to a desk computer (not a remote master) connected to the same LAN of AMX master and the remote directory is of coarse shared (it work when I connect my Notebook to the desk computer)... I made some tries but it seems not working... (I get "-2 = invalid file path or name")
Do I need to implement a FTP client to accomplish the task? ... there is some way to do it easier? - There is some way to test/simulate a Touch Panel on computer without the Panel? ... maybe with G4 Panel Preview and the <Virtual NetLinx Master> connection?
I mean that when you click with mouse on a button or drag a bargraph, the AMX master will receive channel, level event and so on.
By other hand, when AMX master send a command, level or channel on/off the G4 Panel Preview (or whatever in place) react by consequence.
As for #2, it's definitely no. You can preview what a panel will look like, but the previewer does not support channel and level events.
Thanks indeed to DHawthorne & Joe Hebert, I saw the thread [thread]4143[/thread] a couple of days ago and I've been hoping that could be working even with the standard sintax '\\<computername>\<directory>\<filename>' on Windows sys-op, unfortunately it's not.
Moreover, I completely misunderstood (due to my lacking English) thinking that <system number> was already working...
Ok, I will implement a FTP client...
Thanks a lot, Neil
