Module for Autopatch PrecisDSP 18x18
Hi!
I need to control a Autopatch PrecisDSP 18x18. I found a module called Autopatch_Precis_v1.2 .It's corret for me?
How can I control the Volume? By the GAIN command?
Thanks a lot
Alex
Thanks a lot
Alex
I tell ya, the autopatch is very, very easy to program. I'd think it'd be harder to actually incorporate a module than to just do it yourself.
I wouldn't even waste the time with a module.
I personally have never used their module since when I started installing the AutoPatch switchers I knew I had a job coming up requiring multiple Precis 18x18 w/ DSP units that would have to work as one so I rolled my own that is limited to 3 units for a total of 54 zones that share 18 common inputs. The AMX module doesn't have the ability to do this so I didn't want to waste time testing it and using it in smaller jobs.
If it works, use it, unless you have tiime to kill and want to roll your own.
But the response of BCS is not easy to parse....
Thanks at all...
